1990 tracker 8v 5sp supension ?
  • 1430 Views
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
« on: April 24, 2008, 06:30:48 PM »
what kinda springs can i put in my truck that will lift it a little but not make me have to move anything like shifters or brake lines
Offline Element
  • 1902
  • LillyKicker
Re: 1990 tracker 8v 5sp supension ?
« Reply #1 on: April 24, 2008, 09:25:24 PM »
are you interested in a budget lift using coil spacers or do you want to use taller springs? The budget lifts are way inexpensive and some of the coils suspensions can get pricey... There will be a difference in ride quality... This is where you ask yourself... Is the little bit of ride and performance worth the extra $$$$???
Here are some links that can be found in the Archive section of this site:
http://www.zukiworld.com/month_050107/feature_budget-4doorbuild.htm
http://www.zukiworld.com/month_120104/feature_calmini_2inch_install.htm
http://www.zukiworld.com/month_120104/feature_sky_bodylift_install.htm
Jerry!!!
« Last Edit: April 24, 2008, 09:29:20 PM by Element »
Jerry                                                               Member since:   May 14, 2006
zUkTAH
U4WDA
Offline karl214
  • 228
  • I love YaBB 1G - SP1!
« Reply #2 on: April 24, 2008, 09:42:50 PM »
I just threw in a set of one inch spacers in my daily driver, already had longer shocks on it... I can see that even with one inch spacers that it sits higher...
Rust in Peace Black Bugger..1994 sidekick... Planing on a Digger"donuts" and 3 inch bodylift, topped off with 31x10.50's in the spring.New D.D 90 softtop lilblue with the heart of black bugger
Offline Element
  • 1902
  • LillyKicker
« Reply #3 on: April 24, 2008, 09:48:58 PM »
Karl, it starts with a 1" inch spacer.... ::)
zUkTAH
U4WDA
