1995 Suzuki Truck Sidekick 4WD 1.6L 16V MFI SOHC 4cyl high/low rpm when in park
  • 1567 Views
Offline gee wizz
  • 9
 I have a 1995 Suzuki Truck Sidekick 4WD 1.6L 16V MFI SOHC 4cyl just started to have this problem i start it up in park it revs up to 2 rpms put in drive or reverse no high rpms . If i let it in park to run it revs to 2 rpms  then starts to rev up and down from 1-2 rpms. i got new map sensor,cleaned and checked IAC, cleaned throttle body. And still same problem any help afraid to drive don't want to get broke down .
Offline RJkick
  • 634
If it starts really going high and low and stalling that could be the ECM.  Other than the RPMS it drives OK?
Offline gee wizz
  • 9
     Found out the problem was  vacuum  leak in hose from ISC hose
Offline RJkick
  • 634
awesome
