2.0 engine swap
  • 7 Replies
  • 1964 Views
Offline jeff5000
  • 37
2.0 engine swap
« on: May 11, 2009, 12:26:38 PM »
aneyone on here know aney thing about a 2.0 engine swap into a a older tracker
Re: 2.0 engine swap
« Reply #1 on: May 11, 2009, 04:25:47 PM »
yes
Offline jeff5000
  • 37
Re: 2.0 engine swap
« Reply #2 on: May 11, 2009, 08:14:19 PM »
how big job is wiring
Re: 2.0 engine swap
« Reply #3 on: May 12, 2009, 01:03:46 PM »
Takes a lot of time. You can buy a new harness from a lot of vendors on here. Call aftermarket4x4 - Sean has a lot of experience with these swaps.
Offline jeff5000
  • 37
Re: 2.0 engine swap
« Reply #4 on: May 12, 2009, 01:51:57 PM »
i can get engine and harnes all for 85 bucks but i dident kno about it seemed like lot of work but do yo got change the gage cluster on the dache tach ect.
Re: 2.0 engine swap
« Reply #5 on: May 12, 2009, 03:21:06 PM »
Probably the best write-up is on the Aftermarket 4x4 site.
http://members.cox.net/aftermarket4x4/2litertracker.html
They sell the bushings and engine mounts and such you need, and can splice the wiring if you send them the harnesses.  I would fire off an email, they are pretty helpful.  :)
Offline rockyzuk
  • 10
Re: 2.0 engine swap
« Reply #6 on: May 17, 2009, 09:10:34 AM »
Does it require a body lift like in the write up or not?
Re: 2.0 engine swap
« Reply #7 on: May 17, 2009, 10:08:25 AM »
Sean knows his stuff. If he says body lift is needed, then a body lift is needed.
