2inch TJ spacers compatible with Calmini 3-inch?
  • 2054 Views
Offline wiretap_MD
  • 73
  • Where the Road Ends...Life Begins!
« on: July 07, 2004, 06:53:55 AM »
Hi! I'm contemplating in ordering the Calmini 3-inch suspension soon.  I was just wondering if I could use my 2-inch TJ/XJ Jeep coil spacers with it?  If camber issues would be a problem, I already have the camber bolts.  Please enlighten me. Thanks in advance!
'01 Sidekick: OME-Calmini Hybrid Suspension, 1.5-inch spacers, Bilstein 5125 re shocks, 2-inch bodylift, 30x9.5 BFG, Safari Snorkel, ARB bumper, Custom rear bumpe
Offline Kreg
  • 795
  • Yo Ho, Yo Ho, a four wheelers life for me.
    • Island 4x4
Re: 2inch TJ spacers compatible with Calmini 3-inc
« Reply #1 on: July 07, 2004, 07:38:05 AM »
It may be pretty hard on your front end components. (IE Struts and CV joints)
I know that the struts already sit really high on their stroke with the 3" lift, so if you add 2" spacers it would probably max them out. (though don't quote me on that)
Same goes for CVs.
  • 6573
  • 66
« Reply #2 on: July 07, 2004, 08:05:24 AM »
Yes, you could but as Kreg stated you will probably be topping out your struts quite a bit. The Wheeler's coils spacer article describes what you are talking about.
http://www.zukiworld.com/month_050103/feature_wheelers_spacers.htm
Good luck, Eric
Offline wiretap_MD
  • 73
« Reply #3 on: July 07, 2004, 08:11:27 AM »
Hmmm...Wheeler's used a 3/4 inch poly spacer.  What if I used Rockyroad's 1 1/8 inch spacer instead?
Offline explosivo
  • 3157
« Reply #4 on: July 07, 2004, 10:28:40 AM »
Without some Hagen-esque front-end mods, any spacing with the 3" calmini kit seems like a relatively bad idea.
omghi2.us[/url]
Offline wiretap_MD
  • 73
« Reply #5 on: July 07, 2004, 11:14:31 AM »
Ok. Thanks so much for you input guys. Really appreciate it!
