The 32's are looking small.
  • 12 Replies
  • 2765 Views
Offline acw592
  • 28
  • I love YaBB 1G - SP1!
« on: January 07, 2005, 03:41:40 PM »
My tracker currently has a set of 32's. I have 6" of lift and really want to go to 33's. I was wondering if any of you guys running 33's could post some pics. THANKS
jookycola
Re: The 32's are looking small.
« Reply #1 on: January 07, 2005, 04:13:45 PM »
the guy in the picture on the main page (burgundy & tan 98 2-door) is running 33's
my question is what all would need to be done to make a tack/kick road woarthy again after a build up like that (6 inch lift w/ 33's)
i'm going to go with the lower gearing to regain my highway speed.  but is it wiser to put on headers as well?
i love this lift and that size tire just as i said before, my main concern is not being able to keep up with freeway traffic.  check out the readers rides section for more sweet 6/33 combos and some 6/32 combos too.
Offline explosivo
  • 3157
« Reply #2 on: January 07, 2005, 04:34:16 PM »
You're gonna definately want gears with 33's. A header and cam would probably help out a little, too.
Remember, kids, freeway driving and Trackicks with 33's and stock gearing do not mix well!
omghi2.us[/url]
Offline Natebert
  • 1098
« Reply #3 on: January 08, 2005, 03:12:08 AM »
We ran 33's with a Calmini 2 inch modified and a 3 inch body lift.
I'm sure Heather can find the pictures and post them here.
« Last Edit: January 08, 2005, 03:12:23 AM by natebert »
« Reply #4 on: January 08, 2005, 03:12:29 AM »
Road Worthy??? Axle gears and make sure all your steering componets are in good shape. With the Calmini 5.83's I can run my Kick with 33x12.50 MTR's at 70-75 all day long. It could go faster but I'm skerrtttt :P
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #5 on: January 08, 2005, 03:16:07 AM »
Yeah...
Back *RIGHT* before the SAS when my truck looked REALLY sharp..  :'(
Heather Galvin
mudfkr
« Reply #6 on: January 08, 2005, 06:46:52 AM »
What brand of 32"s are you running ?
I run Aussie made 32" mongrels which are a "small" 32x10.5 on a 15x7 with 4" back space and I get no rubbing on the rear guard.
Then the other day I tired a mates 32x9.5 Swamper (nearly an inch bigger O/D then the mongrel  :o) which is on 15x7 with 2.75" back space and it fouled the rear guard while turning. As this is the exact combination that Calmini suggest for rim/tire size for the 3+3 kit, do you have to do some "cosmetic alteration" to the panel work for this to fit ?
Looking at it with a 3.5" back space I'd clear with no trimming but that means losing track width  >:(
good luck with the 33's  ;)
« Reply #7 on: January 08, 2005, 01:37:31 PM »
Little bit of fender trimming never hurts (too much ;))
« Last Edit: January 08, 2005, 01:58:34 PM by trickker »
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #8 on: January 08, 2005, 01:52:57 PM »
That's what I'm talkin about.  ;)
(The white lookin goop is silicone to fill the holes where I cut the floor board! :D)
« Last Edit: January 08, 2005, 01:54:01 PM by Chief »
« Reply #9 on: January 08, 2005, 01:59:36 PM »
The horror :o
Frankinstinien ;)
Offline acw592
  • 28
« Reply #10 on: January 08, 2005, 03:24:45 PM »
I'm running Maxxis 753 mudders(the 32's) on 15x10 white spokes(painted black). I'm not sure what the backspacing is. I had to trim the back lower corner on my front wheel wells a little. Other than that they do fine.Since I don't want to re-gear right now maybee I should stay with 32's for a while. This does ok on the freeway unless there's a head wind ;D
Offline Chief
  • 678
« Reply #11 on: January 08, 2005, 03:46:10 PM »
The horror :o
Frankinstinien ;)
Gawd damn mutha fawkin right!!!!!  8)
People stare, but they ain't sure if cause they like it, or if they can't help it (like lookin at a bad car wreck!)
« Reply #12 on: January 08, 2005, 05:40:42 PM »
I get people about breaking their
necks to get a second look at my
33s on the Kick, they just can't get
the idea that these tires are as big
or bigger than most trucks running
around (non lifted)
« Last Edit: January 08, 2005, 05:45:45 PM by wildgoody »
