2wd to 4x4 conversion...Is it really that easy?
  • 7 Replies
  • 2395 Views
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« on: March 22, 2007, 05:25:39 AM »
I have a 1998 4door 2wd Tracker.  Is it really as easy as everybody says, to convert it to 4wd.  I am thinking about finding an old junked out or wrecked tracker/sidekick and using it to convert my tracker.  Is there any welding involved?
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: 2wd to 4x4 conversion...Is it really that easy?
« Reply #1 on: March 22, 2007, 02:14:43 PM »
Welding?
Nope.. just parts swapping.
Tranny
xfer case
front axle assembly
front spindle/hubs
Driveshafts
mounts, etc....
All the mounting holes should be there.
Lots of work, but pretty straight forward.
  • 6593
« Reply #2 on: March 22, 2007, 03:26:20 PM »
Welding?
Tranny
xfer case
front axle assembly
front spindle/hubs
Driveshafts
mounts, etc....
I don't think the mounts for the front 3rd member/axle assembly are there on a 2wd chassis (the tabs to mount the center section) and would need to be fabricated. Please confirm, over...
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #3 on: March 22, 2007, 06:35:11 PM »
hmmm, the holes for the diff mount were on the 2wd tracker I looked at, but I honestly didn't check for the front two mounts....
I wonder if it varied according to year?  I was looking at a 89 I believe.
Does anyone know for sure, now I am VERY curious.
Offline WDoG
  • 23
  • Zuki'r for life!
« Reply #4 on: March 22, 2007, 06:38:06 PM »
Don't really know anything about this coversion, but wouldn't you have to change out the ECM too?  Isn't there a difference between the 2wd and 4wd one?
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #5 on: March 22, 2007, 08:32:26 PM »
 I drive a 95 tracker that was 2WD everything is just unbolt and swap, except the diff mount right behind the steering box ( have to cut off the 4WD and weld to the 2WD, but pretty minor) as for the ECU there's no problem as long it's 5 spd to 5spd or auto to auto.
 The 4WD light is even in the 2WD cluster, you just have to hook it up. Don't know about all years but I know 94-95 are the same and need the bracket welded on.
 The gears in mine were the same to so I didn't even touch the rear end ;D
 My .02
Steve. :)
When this thing hits 88 MPH your gonna see some serious sh!t (hahaha)
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #6 on: March 22, 2007, 08:37:24 PM »
 My .02
Steve. :)
ah yeah, that is one of the two I didn't check.
OK, I stand corrected... it should have been:
Welding?   yep, but just a little...
 ;D ;D ;D
Offline Yoak
  • 577
« Reply #7 on: March 22, 2007, 08:40:36 PM »
We Just did the conversion on my car....just front diff bracket
