2wd transfer case to 4wd question
  • 26 Replies
  • 5228 Views
Offline Carnage
  • 2453
Re: 2wd transfer case to 4wd question
« Reply #15 on: April 24, 2008, 07:01:29 PM »
Iv only seen a 2wd sidekick...once!
come to Hawaii and ill show you 2 more
 ;D
« Reply #16 on: April 24, 2008, 07:22:29 PM »
what i meant was can you just add a 4wd front housing and an input shaft and shifter and make it a 4wd case?
Yes, you can.
You will need the shifter part of the tcase (that bolts in place of that plate on the front side of the 2wd case, the shifter, shift rails, couplers for the front output, a front output shaft, and you can add the 4wd indicator switch to the shifter housing.
As mentioned though, it may be cheaper to just find a 4wd case or find a 4wd with a broken case and swap the parts over to the good 2wd case.
« Reply #17 on: April 24, 2008, 07:25:08 PM »
You must not get out much......or you live in a place where 4wd is needed a lot. :P
Here in the central US, I see more 4wd trackicks....but I have seen a lot of 2wds too.
« Reply #18 on: April 25, 2008, 07:18:23 PM »
Hello everyone!
A brand new Samurai owner here (FNG) as of 04-23-2008.
Is the 2-wheel drive t-case a reduction box or just an drive offset box?
oh yes...................and................are zuki owners cool with old Jeepers? ;D
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #19 on: April 25, 2008, 07:48:43 PM »
Basicly it's just a drive offset box.
Mean Green Wheeling Machine
« Reply #20 on: April 26, 2008, 06:56:12 AM »
Hello everyone!
It IS a reduction box.....it has the same 1.409:1 high range reduction as the 4wd tcase.  It also offsets the rear output, just like the 4wd tcase too.
Offline Armour
  • 360
« Reply #21 on: April 26, 2008, 10:07:20 AM »
Is there actually a reduction for high range?
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #22 on: April 26, 2008, 11:50:38 AM »
Yes, we are cool with old Jeepers.  New ones too!
We are always looking to expand our minions.  Zukers a tolerent lot.
Ack
Offline Amilla
  • 1076
« Reply #23 on: April 26, 2008, 02:16:56 PM »
In the city i live i have only seen one and
I have seen some real "O-G" 2wd's in other cities.
« Reply #24 on: April 27, 2008, 09:27:38 AM »
ahh So with the 1.409 reduction in the x-case makes it feel like you have 5.25:1 ring and pinion.
Or if you wanted to drop the x-case you would have to run 5.25:1 R&P to get the stock performance.
Offline RHodge
  • 523
« Reply #25 on: April 27, 2008, 05:32:25 PM »
Yep, and with the 6.5 gears you put in yours it's even lower  :)
« Reply #26 on: April 29, 2008, 07:22:19 AM »
No, I just make the stuff up that I post. :P
Yes, there is a high range reduction in the 2wd tcase.....just like in the 4wd tcase.  All 86-95 samurais run the 1.3 engine and the 3.73 axle gears......so just because it is 2wd, doesn't mean it can get away without running the reduction in the tcase.....it would be pitifully slow and underpowered with a 1:1 high range (like the samurais aren't already).
Exactly.
