33s, daily driver, help
  • 9 Replies
  • 3530 Views
Offline Ether
  • 15
« on: July 20, 2009, 09:43:54 PM »
got my hands on a sammi. no engine,no trans everything other than that is there. now, that said i have a bud with a sammi on 33 boggers. 5.13 gear stock 1.3 and trans power on the street not even close, trail power is great in low range but i want to sell my camaro and drive the sammi daily. can anyone help me out here. i want to run 33s on mine a/ts for the street and boggers off. i dont need a powerhouse, i dont want to leave black marks all over and i dont want to race mustangs i just want to the power to drive daily without turning over 3000rpm at 55
IF YOUR NOT BREAKING PARTS YOUR NOT WHEELIN HARD ENOUGH
Offline v-stone
  • 625
Re: 33s, daily driver, help
« Reply #1 on: July 20, 2009, 10:42:37 PM »
Zooks are build for high RPMs. I commute 60 miles a day and keep the rpm's up between 3-4000. Try that with a bigger engine (chev) and it will not last, zooks will. Try the 33" skinnies, I love mine.
SAS Tracker! No looking back now.
Offline Amilla
  • 1076
« Reply #2 on: July 21, 2009, 06:51:58 AM »
6.5:1 T-case gears will do you right with 33's.
Amilla
Offline Luc
  • 51
« Reply #3 on: July 21, 2009, 09:17:03 AM »
1.6 swap? 2.0?
Offline sammypro.com
  • 153
« Reply #4 on: July 21, 2009, 09:24:13 AM »
keep it a sammy.
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some freakin' muscle.
http://www.facebook.com/#!/sammypro
Offline Ether
  • 15
« Reply #5 on: July 21, 2009, 03:12:28 PM »
got a 1.3 needs rebuilding. im gonna use 5.13 tracker gears any tips while im rebuilding the engine to help with power while keeping it reliable and hopefully getting me closer to my goal.it will have stock trans 5 speed
  • 6593
« Reply #6 on: July 21, 2009, 04:29:09 PM »
I'd recommend getting a low-range t-case like mentioned earlier. The Samurai cases have hi-range reduction too so that'll get the motor spinning on road and help. 3500-4000rpm all day long is a happy range for the 1.3 and 1.6. Second thing is I'd swap in a 1.6 engine with the fuel injection if you can swing it. If not, the Samurai intake and exhaust will bolt to the 8-valve and you'll still have a huge hp increase over stock.
Good luck, keep us in the loop.
« Reply #7 on: July 23, 2009, 06:14:17 PM »
I'd run the 1.6L 16V or 2.0L w/ the Shogun doubler. But hey - that's me.
Offline elf
  • 102
  • ~~~ZUKIUP~~~
« Reply #8 on: July 23, 2009, 08:49:37 PM »
I run 33x13.50 toyos with a 1.3 stock t-case and 5.13 tracker gears in my sammy all  the time . RPM runs about 3400 with anerage speed at 60mph.....ZUKIUP
Suzuzi:: Squeeze between the shit they cant crawl over
phloop
« Reply #9 on: July 23, 2009, 09:37:25 PM »
My new combo is a fresh 1.6 8V with a hawk stage 1 cam, header and a MS2 with a 44mm carb, 4.16 TC gears, 5.12 R&P and 32" swampers. Had a worn out 1.3 with a weeber before. The new 1.6 has a good power range for DD use and I don't have to wined it as tight as the old engine needed to be. If it was my only rig I would go with the 4.62 R&P gears to have a little more top end on the freeway.
