3rd link spacer dimensions
  • 7 Replies
  • 2571 Views
« on: August 24, 2011, 01:17:30 PM »
i need dimensions for a 3rd link spacer for a 91 sidekick. it has a 2 inch lift. can anyone help me?
« Last Edit: August 24, 2011, 01:19:56 PM by aviation officer »
Re: 3rd link spacer dimensions
« Reply #1 on: August 24, 2011, 04:02:44 PM »
Make sure the welds are good.  The ZW Challenge had two busted 3rd link mounts.  Granted they were pushing it, but shows the amount of forces at work there.
« Reply #2 on: August 24, 2011, 08:37:15 PM »
i dont do major off roading. i saw a spacer online but i want to make my own so i can tilt the axle up a little bit.
« Reply #3 on: August 28, 2011, 08:06:36 AM »
You want it equal to your lift.
  • 6573
  • 66
« Reply #4 on: August 31, 2011, 07:35:08 AM »
Hi Steve - I had heard about Fuller's link breaking but didn't hear about a second one. Did you guys have trouble with that too? Aren't you running stock parts back there?
« Reply #5 on: August 31, 2011, 07:57:32 AM »
First breakdown was a cold weld on lifted mount.  They allowed me to go in and get part between the starting groups (while Peggy found a welding shop online to repair it), then take it back in after last group.  That is what put Kris 2 1/2 hours behind everyone.
We have 30" lower arms, and a modified upper link.  With the motor switch not enough time to 4 link it.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #6 on: September 07, 2011, 01:42:10 PM »
Read this over, it may be another option for you. I personally prefer this over a spacer.
http://www.zukiworld.com/month_100102/feature_hagans_rearrotate.htm
Offline chrisvitarasport94
  • 228
« Reply #7 on: September 08, 2011, 11:51:40 AM »
i originally had a block with long bolts, but they failed
now have an H shaped one, and offset, to sort out the angles
http://www.bits4vits.co.uk/store/vitara-/-x90/rear-axle-2-spacer/prod_42.html
'94 3dr s/top Sport, roof bars, roof lights, Calmini bumper, SuperwinchEP9, CB & handheld, GPS, 2" body lift, skid plates, 2.5" susp lift, & hi-lift. Safari Snorkel. R Lockright
