3rd Member Play - How much is too much?
megaton
87
I Love ZUKIWORLD!
October 05, 2012, 07:38:05 PM »
I'm in the process of replacing both rear wheel (axle) bearings on my 86 Sammy and there is a fair amount of play in the 3rd member. How much play is too much?
Drone637
8121
116
Evil Cow
Re: 3rd Member Play - How much is too much?
October 07, 2012, 12:22:41 PM »
What do you mean by play? Do you mean movement in the pinion before the gear engages or is the flange loose and move around?
megaton
87
I Love ZUKIWORLD!
October 08, 2012, 07:42:37 AM »
Hi Drone. I mean movement (rotation) of the pinion before the gear engages. Mine has quite a bit, maybe 1/4 turn each way, forward & reverse. The flange seems solid.
Last Edit: October 08, 2012, 07:52:29 AM by megaton
Jonny Rash
1094
21
Too many Samurais, too many little boys!
Reply #3 on:
October 08, 2012, 08:42:26 AM »
Do you have a lunchbox locker? If so, that it pretty much normal.
Even stock, the diffs do have quite a bit of play. 90 degrees seems pretty excessive, but if it isn't groaning or grinding, I wouldn't worry about it.
35 years of Samurai ownership, and I still have my very first one.
megaton
87
I Love ZUKIWORLD!
Reply #4 on:
October 08, 2012, 08:49:33 AM »
Thanks for your reply Jonny. It's stock. I guess I'll worry about it later.
Drone637
8121
116
Evil Cow
Reply #5 on:
October 08, 2012, 02:32:24 PM »
If it hasn't been touched I wouldn't worry about it. Unless you want to pull the third member out and check, which isn't that hard if your axles are already out.
