4dr shocks
4dr shocks
speech97
10
4dr shocks
August 01, 2009, 01:13:50 PM »
hi i got a 97 2 dr tracker all stock and i got a 95 4 dr sidekick sport i am installing the springs from the 4 dr on the 2 dr and i was wondering what all i need i know i need longer shocks and i was wondering if the rear 4 drs are longer then the rear 2 dr if so could i just run the 4 dr shocks or do i need to get crown vic and for the front could i run the 4dr struts or do i need the strut spacer thanks
Uncivilized
1469
Re: 4dr shocks
August 01, 2009, 01:24:39 PM »
The Sport springs are going to give you about 1.5" of lift, mostly because they are stiff - you're 2 door will be quite rough with these.
You should have longer rear shock, and flip the strut mount.
speech97
10
Re: 4dr shocks
August 01, 2009, 01:33:15 PM »
r the 4 dr shocks and struts longer then the 2 dr shocks and sturts or is the mounting points just different to make up the different spring length?
