OTT Industries 'Kicker 2'
  • 2852 Views
Offline Natebert
  • 1098
« on: October 20, 2003, 04:29:20 PM »
Gang,
Has anybody any experience with the OTT Industries 'Kicker 2' case?
This type of setup looks like a REALLY good idea for those like me that that want this type of setup.   (dual transfer cases, fixed driveline flanges)
My reasoning is that the fixed flanges allow for more drive line options when going to solid axle.  The additional transfer case provides more gearing options.  AND, if you want, it also looks like it'd make going to toyata drivelines/axles easier.
But I'm really interested in if anybody have any feedback on this product?
~Nate
Offline pbgbottle
  • 76
Re: OTT Industries 'Kicker 2'
« Reply #1 on: October 21, 2003, 03:54:43 AM »
you  can give Reo a call at "no limit offroad ". he built a
sidekick 4dr.model using this setup, or one of ott's other case options. he ran a 4dr with solid axle and 35's with dual t-case the front end was leaf spring setup though no coils .still looked cool , i think heather has a shot of his truck on her site .the white 4dr  .Reo's phone #
 (604)526-5268   b.c. Canada
or you could phone breeze industries
( breezeindustries.com  ) they have a cool site for the sami's  . might have some info they where the ones who told me about .ott industries .
                   Jake
1997 suzuki sidekick
4dr. auto
Calmini 6 inch
31x10.5 yokohamas on american racing 15x7
see the machine at http://www.cardomain.com/id/pbgbottle
Offline Natebert
  • 1098
« Reply #2 on: October 21, 2003, 03:34:33 PM »
Thanks for the info.  I'll look into this further.
~Nate
Offline Natebert
  • 1098
« Reply #3 on: October 22, 2003, 05:22:52 PM »
The lack of replys tells me that there aren't too many folks running on this type of setup.
Has anybody given dual transfer cases any thought or is the mainstream to run the 4.x : 1 transfer case gears produced by various sources?
~Nate
Offline mrfuelish
  • 2862
« Reply #4 on: October 22, 2003, 05:50:35 PM »
I sent them an e-mail about a week ago asking them some questions and they haven't returned it yet so??? it will shorten your drive shaft about 12"s or so if you have the room it will give you more gearing options also check out spidertrax.com they have some there that might work.
Offline pbgbottle
  • 76
« Reply #5 on: October 23, 2003, 02:59:33 PM »
i will be running this setup for sure ,just have to get the bucks together .length isn't much of an issue ,i drive a 4dr. like nate said fixed driveline flanges ,this is a huge
option , goin with the toyota  t-case also lets you use
a factory toyota's cv-joint  driveshaft so you can perform the diff rotation properly . with a solid axle up front that will give you the option to go quite a bit taller in the lift department, and for gearing options the toyota t-case has tons of aftermarket gear options ,and with a longer front driveshaft and a solid axle the caster angle won't be such an issue ,no cutting and rotating of the steering knuckles .the whole damn setup will be sweet. and goin with this option might save you some money by not having to buy the 5.83's   and to have them installed ,everybody should be able to install an extra t-case and new shafts
  anyways that's my too!! bits !!
                                                          Jake
also for me it is an easy option ,for i only live half an hour away from them .....
4dr. auto
Calmini 6 inch
