Error 51 EGR System on '92 4dr Sidekick
  • 1 Replies
  • 1330 Views
Offline RJkick
  • 634
« on: April 09, 2008, 05:50:56 PM »
Backround - Failed smog with Check Engine light
Went to Gold Shield Smog Station recommended by California C.A.P. program
The shop replaced the EGR valve, adjusted the cam 3 degrees as they said itr would not pass timing without it.
The light is still on so I took it back and received the response that there is nothing wrong with it and that since I have a "California" legal Header, aftermarket cat, and muffler that the sensor isn't getting enough backpressure for the system.
I was trying to clean out the egr pipe that goes to the sensor but it looked like there was a bb or small round object that wouldn't allow me to clean from end to end.
Has anyone else run in to this?   Should I try to pop the ball out?  Is it supposed to be in there?
Offline RJkick
  • 634
Re: Error 51 EGR System on '92 4dr Sidekick
« Reply #1 on: April 10, 2008, 11:46:01 AM »
Any ideas on how to pop the bb looking obstruction out
