Tracker Rollcage?
  • 3684 Views
Offline Dillboytos95
  • 24
Tracker Rollcage?
« on: September 21, 2009, 05:48:31 PM »
Mom won't let me go out without one, so which one calmini full or rear bar or Shrockworks? I think calmini cause shrockworks is bolted not welded and calmini is cheaper. Any suggestions? thanks
95 Geo Tracker
2" Coil Spacer
31/10.50/R15
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
Re: Tracker Rollcage?
« Reply #1 on: September 21, 2009, 10:15:52 PM »
  The only tracker roll cages I have seen for purchase, are the Petroworks and the Calmini cage. Trail Tough has made one, but is not offered yet on their site. The calmini one is a solid weld up design, but the Petroworks is a full 6 point bolt up cage.
  • 6602
  • 69
« Reply #2 on: September 22, 2009, 08:34:04 AM »
Here's a link to our Gear Guide section and a review of the Petroworks cage.
http://www.zukiworld.com/month_120108/feature_gear-guide-petroworks-sidekick-roll-cage.htm
Hope that helps.
  • 24
« Reply #3 on: September 22, 2009, 10:11:45 AM »
Ok thank you for your help i think i will go with the calmini cage
95 Geo Tracker
2" Coil Spacer
31/10.50/R15
