'87 Samurai ignition question?
  • 1062 Views
Offline edjahar42
« on: May 15, 2010, 03:13:43 PM »
My '87 Sammy has had a screwdriver driven into the ignition, failed theft attempt.  I got the lock to turn again with the key but if it's supposed to it doesn't lock the column. I can't find a replacement and if I use it as is I'm worried about the steering wheel locking when I don't want it to. I'm going to be towing it flat with a towbar.
All response appreciated.
Ed
ED
Offline crgm101
  • 80
Re: '87 Samurai ignition question?
« Reply #1 on: May 17, 2010, 12:15:36 PM »
autozone has the lock assembly for 40 bucks online it looks like it has the steering lock
« Reply #2 on: May 17, 2010, 12:24:54 PM »
You can also give Hawk Suzuki a call, they should be able to hook you up with the parts you need.  They are great to deal with when it comes to non-standard part replacements.
Offline crgm101
  • 80
« Reply #3 on: May 17, 2010, 12:26:37 PM »
hawk suzuki is probaly the best bet atleast you know you will get the right part the first time
Offline doughboy0379
  • 290
  • 9
  • Blinker fluid is free so use it........
« Reply #4 on: May 18, 2010, 01:41:18 AM »
if you do not ever want it to lock again you could probably cut/grind off the part that locks into the side of the steering shaft, not necessarily the best way to go but it is cheap LOL
86 Samurai, SPOA, 3" HD leaf springs, 31/10.5/15 Big-O XT Tires, K&N Air Filter, Doug Thorey Header, more coming when I find the funds :)
Offline edjahar42
« Reply #5 on: May 21, 2010, 01:05:34 PM »
Thanks all for your help, I'm giving Hawk a call.
Ed
ED
