Pulling front 3rd
Pulling front 3rd
Quaddawg
1622
Flex and Ground Clearance is HIGHLY overrated!!
Pulling front 3rd
February 07, 2006, 01:00:04 PM »
What is the easiest way to get the front pig out?
I just glanced under there, and it looks like the crossmember is in the way... What is the easiest way to get her out... I will eventually get myself down and grab a chiltons... but you guys know all the short cuts!
wildgoody
8134
67
Re: Pulling front 3rd
February 07, 2006, 06:08:07 PM »
The front is the worst one, you got to drop
the axle housing, which means taking the
front CVs apart and loostening the struts
and brakes, not bad, just lots of stuff in the
way, the front center link might get in the
way too.
Quaddawg
1622
February 07, 2006, 08:00:27 PM »
That is what it looked like.... oh well, not a biggie, all the front end stuff should loosen easily, I just had it all off for the lift.
Guess I will deal with the CV's when I get to them.. would be a good time to replace them I guess... or at least make sure they are nice and tight..
Guess, I better go get a manual.. at least I have a lift available for this swap... whew.. didn't feel like doing THAT on the driveway...
Thanks WG..
wildgoody
8134
67
Reply #3 on:
February 07, 2006, 09:18:10 PM »
Last time I dropped the front axle
I was working in the dirt
No ramps needed tho with 33s and 3" lift
