Which 2" lift for my desert/street application?
  • 1277 Views
Offline robozuki
  • 33
« on: February 26, 2007, 09:34:12 AM »
Ok so I recently got 5 new rims and tires on my 97 4-door kick.  15x7's that have the tires sitting about an inch oustide of the sheetmetal, looks just how I wanted.  The tires are one size bigger than stock (but 2 sizes up for me since it came with smaller-than-stock tires)  I don't remember the size and am too lazy to go out and look, I think it was 215/70 or something like that.
It's my daily driver and I wheel it in the desert.  No crawling really, but lots of tennis-ball to grapefruit sized rocks, ruts, and occasional loose sand.  I haven't really had a need for any more flex, as I don't try to take on any crazy off camber stuff.  The desert out here is pretty flat.
I mainly use it for getting my mountainbike to trailheads and for camping, so often it's on chattery washed-out fire roads.  The new tires/wheels have already improved the ride and handling around corners (perhaps due to the wider track width, I'm not sure).  I would like a tiny bit more ground clearance up front and honestly I just don't like how it looks, kinda nose-divey.
I just want to lift the front only, aprox 2" or so.  I saw some spacers on ebay for the struts.  I'm a little confused about what I'll need to provide the correct camber, as well as a good smooth ride on and off the highway.
I'd like it to soak up the small ruts, rocks, and washboard surfaces better.  Should I go with coil spacers, strut mount flip, and camber bolts?  Or longer springs and struts?  Or should I just buy the Calmini 2" kit and get the control arms, and then not install the rear portion of the kit?
I want something that I can revert to stock if I sell the rig, so I don't wat to drill any wierd holes if I do some kind of flip.
I can afford the Calmini kit, but would only go that route if the ride is improved.  Otherwise I'd like to spend less if all I'm gettin' a couple inches of clearance.
Doesn't have to be exactly 2", just ballpark.
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Which 2" lift for my desert/street application?
« Reply #1 on: February 26, 2007, 09:50:50 AM »
Sounds like the previous owner changed out the front coils.  Kicks don't normally look "nose divey".  For all you're doing with it, I would probably just air down - take the tire pressure down to 12-15 PSI when you're on the rough stuff, and it will ride a lot better.  Just remember to air it back up to 23 when you're done!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #2 on: February 26, 2007, 12:54:17 PM »
They always did over here. The front tends to look about an inch or so lower than the rear.
« Reply #3 on: February 26, 2007, 03:28:05 PM »
Yeah, my front end was always a bit lower than the rear. About an inch, so I just added a bigger spacer in the front. Try the OME lift for good ride quality and handling characteristics.
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #4 on: February 26, 2007, 04:00:06 PM »
I agree also. The OME kit it good for this application. Every tracker Ive had has sat low in the front.
Mike
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #5 on: February 26, 2007, 06:36:33 PM »
You made me go back and look, Mike.
I guess my 2-door DID look a little droopy before lifting.
Bob
