94 16V loss of power
DirtDevil
317
Island4x4.com
September 02, 2009, 10:15:58 AM »
Just picked up a 94 4 door 16V auto.. trying to figure out the issue its having.. it seems to start and idle just fine.. but it rev's extremely slow and lacks power untill about 4500 rpm.. it seemed like the cat was plugged so i unbolted that.. it was fine.. checked timing, it was good too.. compression is good.. airfilter clean.. plugs good... any idea's? im thinking the timing belt may have jumped a tooth ?
Sj410 Full exo, Locked, race buckets, 5 point
85.5 LWB sami, Toy axles, locked rear, CJ/RUF, warn 8000, 33's
DirtDevil
317
Island4x4.com
Re: 94 16V loss of power
September 02, 2009, 12:19:50 PM »
oh and also its not flashing any codes.. just 12
biker
730
7
It's a sickness I tell ya
September 02, 2009, 09:40:58 PM »
replace the fuel filter Trev
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
DirtDevil
317
Island4x4.com
Reply #3 on:
September 02, 2009, 10:02:29 PM »
yep thats what ive narrowed it down to today i think... did a bunch of sensor testing.. took off the timing belt cover all was good.. time to toss in a new fuel filter.. cap rotor and plugs and it "should" run great
DirtDevil
317
Island4x4.com
Reply #4 on:
September 03, 2009, 07:35:26 PM »
changed the fuel filter today.. along with cap rotor and plugs ... still no change.. so i checked even more sensors and found nothing wrong.. all with in spec ( intake are temp, MAF, coolent temp, 02 ect.. ) so now the only thing left i can think would be maybe bad injectors or low fuel pressure... and if all that looks good, maybe bad gas???
or even the comp
DirtDevil
317
Island4x4.com
Reply #5 on:
September 05, 2009, 01:54:26 PM »
hmm still no luck.... tryed seafoam today... made a big cloud of smoke.. thats bout it.. i also ordered a fuel pressure tester any one have any more idea's?? it makes good power from 4500 up and revs normally.. below that it revs very slow.. and if you mat it off idle it strugles and doesnt rev up
biker
730
7
Reply #6 on:
September 06, 2009, 07:42:13 AM »
Have you checked the timing? One other thought came to mind, did you run it with the cat out or just look at it? I had one that the muffler collapsed internally and restricted the exhaust causing problems.
99 Vitara 2wd
10 Gr Vitara
DirtDevil
317
Island4x4.com
Reply #7 on:
September 06, 2009, 01:09:23 PM »
yea i checked the timing.. pulled the cover off to look at the belt and make sure its all lined up... each plug is firing doesnt seem to miss a beat on the timing light.. i ran it with open exaust.. didnt make a difference.. im starting to think it might have a weak fuel pump, i ordered a fuel pressure tester at lordco should be here on tuesday.. but if i pinch off the return that comes off the regulator it doesnt seem to make a difference how it runs
Hillbillydave
213
Reply #8 on:
September 06, 2009, 08:44:42 PM »
When you mat it from idle, does it belch black smoke?(rich condition)
What about dizzy timing? You say you put a timing light on it, should be about 8 degrees. Sounds to me like its way retarded, timing wise. Just my guess.
'89 sidekick 1.3L 3" blue suspension parts, custom strut extensions 31x10.5 Mud Trac's on 10" rims rear fenders trimmed, lincoln locked rear, Rochester Carb on custom adapter
93 Sammy project, SPOA with 34's, 5.12's, welded, in the works
DirtDevil
317
Island4x4.com
Reply #9 on:
September 08, 2009, 04:58:26 PM »
hmm so it finally flashed me some codes.. one for the TPS and one for the MAF... so i cleared the codes and tryed again.. TPS came up.. but no MAF... i put the ohm meter on both sensors .. the MAF reads just fine.. but i cant seem to get the TPS to adjust to where it needs to be set ... my fuel pressure tester finally came in so ill be checking that tomorrow.. i also ordered a TPS today to concidering it was alot cheaper then i thought it would be ($60)
Skyhiranger
3734
122
I don't buy, what I can build
Reply #10 on:
September 10, 2009, 09:07:30 AM »
TPS problem would be my guess.
Fuel pressure is not likely the problem. If it was a fuel pressure issue, I would suspect it would run better on the lower end, than on the top end.....less fuel needed at low RPM than at higher RPM.
16Vs are usually spec'd at 5* for timing.
DirtDevil
317
Island4x4.com
Reply #11 on:
September 11, 2009, 06:15:01 PM »
replaced the TPS , checked fuel pressure, and volume.. and still cant figure out the problem... also pulled the valve cover off to see if maybe theres a stuck valve but they all look normal.. im running out of idea's... starting to think maybe the computer is bad?
Skyhiranger
3734
122
Reply #12 on:
September 11, 2009, 07:35:48 PM »
Did you change the spark plug wires? I have seen a bad one make it run crappy while accelerating.
What was the timing set at, when you checked it?
Could be a bad ECM. Only way to know for sure is to swap in a known good one.
Did you adjust/check the valves, to make sure they are set correctly?
philc72
65
Reply #13 on:
September 11, 2009, 07:38:43 PM »
my thought is that they are slow until upper rpm range anyways usually a motor that is slow to build rpm is a bit tired in my opinion
DirtDevil
317
Island4x4.com
Reply #14 on:
September 20, 2009, 01:06:50 PM »
this things still got me stumped... im almost tempted to take it to a shop and let them deal with it... and that would be a first ever for me!
