94 kick alarm
  • 9 Replies
  • 2436 Views
Offline Lasher
  • I love YaBB 1G - SP1!
94 kick alarm
« on: June 29, 2005, 04:51:19 PM »
i recently purchased a 94 kick.  does anyone know how to disable the stock alarm, will this coz it not to start?
the front end has been hit, maybe a sensor?
Offline echojeff
  • 414
  • Lo que sea
Re: 94 kick alarm
« Reply #1 on: June 29, 2005, 05:00:08 PM »
The alarm "key" fell out of mine while bumping down the road this weekend.  and no starto.  I was by myself, and I had to push it to start it.  Then I remembered feeling somthing hit my leg then the  floor earlier.  I found the "key" and put it back in and it started right up.  I would like to know how to be rid of it too, since without a remote for it , it is of no use, and it can only cause trouble later I bet.
95 Kick 4dr JLX.
Offline Lasher
Re: 94 kick alarm
« Reply #2 on: June 29, 2005, 05:09:22 PM »
cool i will check that.. anything else?
i am new to the zuki world.... so thanks man
Offline Lasher
Re: 94 kick alarm
« Reply #3 on: June 29, 2005, 05:14:54 PM »
is the "key connected to a wire?
Offline echojeff
  • 414
  • Lo que sea
Re: 94 kick alarm
« Reply #4 on: June 29, 2005, 05:25:58 PM »
It plugs into a socket thing under the dash to the right of the steering wheel. The plug socket sticks out flush with the dash, so it is not way underneath.  Maybe late tomorrow I can get a picture.  It  looks like a card that would plug into to a computer motherboard, but it is smaller with the metal contacts much bigger than what you would see on a computer board. The "key" contact surface is about a inch wide, with a handful of metal contacts. I have a 95 JLX, so it may be similar.
Jeff
« Last Edit: June 29, 2005, 05:27:06 PM by echojeff »
95 Kick 4dr JLX.
Offline Lasher
Re: 94 kick alarm
« Reply #5 on: June 29, 2005, 05:37:04 PM »
so if i unplug it... its not disabled? it has to be plugged in. so here lies my prob. when i get in i hear a click click and all my side indicators flash. so i cannot start the car.
so is there a way to bypass this system? thanks for the replys guys!
Offline Mythose
  • 361
Re: 94 kick alarm
« Reply #6 on: June 29, 2005, 06:41:43 PM »
Does the horn honk when you try to start it?
try turning on the lights, if that dont work try turning on the wipers - radio - call the person that you bought it from its probably somthing they forgot to tell you
same thing with my 95 tracker would just honk when you tryed to start it, then you turn on the lights and vroom
Offline LawDog
  • 531
  • Lakeview Motor Sports' Makin it Hert! Tell u whut!
    • Emerling Chevrolet
Re: 94 kick alarm
« Reply #7 on: June 30, 2005, 03:11:15 AM »
I wasn't aware of a factory starter kill in that year trackick.  Is this aftermarket??  You could try pulling the wires out of that unit and bypassing it.  Don't hack it up too much though, make sure you can rewire it if the idea doesn't work.
"I'm the Law 'round here" said the Duckshirt.
Get a Zuk, Get it dirty, Git-R-Done!!
At Lakeview Motor Sports we specialize in rediculousness, hackdome, and wasting your time.
Offline breadbox
  • 119
  • Me Like Doughnuts!!
Re: 94 kick alarm
« Reply #8 on: July 02, 2005, 02:45:12 PM »
I think you need some duct tape some tin foil and a safety pin.  Put it all to gether and hook it to your shirt and maybe that will help it start.   ;D ;D  Just kidding.
1.3 ltrs of FURRY!!!!!!
Offline Lasher
Re: 94 kick alarm
« Reply #9 on: August 10, 2005, 10:50:05 AM »
sounds hot breadbox....... whats your sign?
