95 KICK D.S. DOOR HANDLE
  • 2234 Views
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« on: April 03, 2004, 03:15:08 AM »
OK OPENS FROM OUT SIDE BUT NOT INSIDE  ???  STARTED AS HAVING TO PULL HANDLE 2-3 TIMES FOR IT TO OPEN FROM THE INSIDE NOW NOTHING  ???  ANY THOUGHTS .......THANKS  IN ADVANCE FOR YOUR COMMENTS & HELP    :-*  MATTY D.  ::)
Re: 95 KICK D.S. DOOR HANDLE
« Reply #1 on: April 03, 2004, 05:21:51 AM »
There is a little flemsy bar that runs from the handle to the latch. It has probably bent through years of use. I also had the plastic peice break that the bar attaches to. Pop the door panel and check it out, both are easy replacements.
  • 2274
« Reply #2 on: April 29, 2004, 01:52:53 PM »
OK FIXED MY DOOR HANDLE .......ALL IT TOOK WAS TO LUBE UP THE LATCH & STUFF  :o  IMAGINE THAT ...SIMPLE FIX...THATS A 1ST FOR ME.......USUALLY ITS THE MOST COMPLEX PROBLEM THAT HARDLY EVER HAPPENS . THAT HAPPENS TO ME  :P   MATTY D.  ;)
