31's and 4:1 t-case. To Low??
  • 9 Replies
  • 1779 Views
Offline MIDZUKI
  • 17
  • "if it breaks, just put some more weld on it"
« on: December 16, 2005, 11:51:15 AM »
would a 4:1 t-case be to low geared for 31x 12.50 boggers ? I have an 87 sammy ?
87 zuk, locked, geared, mightykong, 33's
Offline truckasaurus44
  • 265
  • I'm a new world Samurai & a Redneck nonetheless!
Re: 31's and 4:1 t-case. To Low??
« Reply #1 on: December 16, 2005, 12:57:11 PM »
2 points:
1) there is no such thing as too low! ;D
2) I've been running 4.16 t-case gears and 31" swamper thornturds whithout a problem.  If anything, I wish I went lower to the 4.9 gears from trailtough.  technically the 4.16 gears are about right for 30" tires in high range but 31's seem to be fine....having a 16valve 1.6 helps.
Offline dsumers
  • 72
« Reply #2 on: December 16, 2005, 02:44:00 PM »
Go as low as you can afford $, you will always want to be lower.  IMO , 4:1  is not nearly low enough especially on long steep hills.  THe new chassis I am currently building will have 8-1 t-case, 5:38 gears and another t-case to reduce almost another 2-1.
Offline mrfuelish
  • 2862
« Reply #3 on: December 16, 2005, 09:30:00 PM »
my first rig had 31's and a 4 to 1   x-fer case and I was allways smelling clutch when wheeling it hard even with a dual friction clutch, I just ordered a 6.4 to 1 set, I would of gone lower but I don't think that the stock case would hold up to much more and did not want to spend 600.00 big ones for a billit case.
Offline ZeusZuki
  • 411
« Reply #4 on: December 17, 2005, 12:09:37 PM »
Hi Midzuki,
4.16 gears are Ok if you are only playing in the mud and have a good strong running motor.
5.14 gears are a real good allrounder for mud a bit of rock crawling and general off camber / go slowish situations - you can use all 5 gears in your tranny to get a gear that works.
6:1 and lower are really only suitable for hard core rock crawling and the likes ( not what all of us are into ;) ) - but way too low to get your rubber spinning in the mud.
NOTE: These are my experiences in various rigs. All these rigs where fitted with 3.9 ring and pinions ( standard )  :D.
I hope this helps.
ZeusZuki :)
Offline ZeusZuki
  • 411
« Reply #5 on: December 17, 2005, 12:37:10 PM »
Oh yeah - all running 31's :)
Offline mrfuelish
  • 2862
« Reply #6 on: December 17, 2005, 12:46:57 PM »
Hey zeus,   sorry could not resist,   have you ever been snow wheeling or following a large group, I don't think that 8 to 1's would be to low, and also with the 6 to 1's it lowers your high range also so if you want to spin tires put it in high range.
Offline ZeusZuki
  • 411
« Reply #7 on: December 17, 2005, 01:03:39 PM »
Hi mrfuelish,
Yes, even us Kiwis get snow. Been wheeling in the stuff up to the grill ( SPOA Sammie ) and yes we do wheel in groups.
These are MY experiences and I am just letting MIDZUKI know what works for me and other club members - I am a member of a Zuk only club, 40 odd members at last count ( and all Zuks ;D ).
I still believe that 5.14 is a good all round ratio ;) on a fairly standard rig.
Just some feed back - not the last word on gearing. I do not profess to be the last word on Zuk mods - just helping out the forum.
How about you?
ZeusZuki.
Offline MIDZUKI
  • 17
« Reply #8 on: December 17, 2005, 03:16:21 PM »
Thanks my rig isnt heavily modified 2" shackle reverse and 1" body. i wheel it alot and also drive daily. i was mainly worried about street drivability.
Offline ZeusZuki
  • 411
« Reply #9 on: December 17, 2005, 05:47:08 PM »
MIDZUKI,
The 416 gears compensate for 31's OK but the 5.14 gears give you back your "standard" gearing in hi box again - eg: 3400 rpm at aprox 60 m/hr - 100km/hr.
Good luck and I hope it all works out ;)
ZeusZuki
