2" shackel qquestion samurai
  • 1193 Views
« on: January 23, 2009, 09:38:51 AM »
If I add  2" shackels to my samurai to get a extra inch of lift do I need longer shocks or any steering mods.Thanks Mike
Offline norcalwreckchaser
  • 128
    • www.norcalwreckchasers.ning.com
Re: 2" shackel qquestion samurai
« Reply #1 on: January 23, 2009, 05:49:09 PM »
You should be OK, I assume you are replacing front and rear. I did this long ago and the only "problem" I had was the steering wheel was off center, I simply set the front wheels straight and disconnected the steering shaft at the fire wall and centered the steering wheel.
As for the shocks, I would replace them if you want to gain any travel from your new lift, I ran a set of used Rancho 5000s up front and some Monroe's out back. Hope this helps.
Norcal
86' Samurai, 5" spua lift, rear missing links, 4.57 gears, 4 to 1 Transfer Case, Lockrights F/R, ARB Front bumper, Doug Thorley Header, Rock Rails, GM alt. swap and other Misc. goodies.
Sold 7/10 :(
« Reply #2 on: February 01, 2009, 07:25:39 AM »
Thanks for the info.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #3 on: February 01, 2009, 09:30:37 AM »
Norcal
Yep I agree, I ran 2 inch longer shackles and had to do longer shocks, but that was because I was also going SPOA.
Offline idaholwb
  • 772
« Reply #4 on: February 01, 2009, 08:47:09 PM »
 You don't have to touch anything to make it driveable. It is a good idea for slightly longer shocks if you want a little more downtravel.
97 Sport
265/70-16s
2" lift
2.0 swap
