97 sidekick 4x4
  • 1608 Views
Offline Kp7
97 sidekick 4x4
« on: January 21, 2006, 04:26:20 PM »
I own a 97 sidekick 4x4 and would like to add a 3 inch suspension, is there any welding or drilling involved.
Re: 97 sidekick 4x4
« Reply #1 on: January 21, 2006, 05:44:20 PM »
Suspinion lift? No
BodyLift, yes.
Are you making your own suspinion lift or buying one?
Offline Kp7
Re: 97 sidekick 4x4
« Reply #2 on: January 21, 2006, 07:24:38 PM »
I plan on buying one.  Not too sure which system to buy.  Also if I put a 3 in suspension lift can i fit 31's on my zuki?
Re: 97 sidekick 4x4
« Reply #3 on: January 21, 2006, 07:34:52 PM »
I've heard it being done.
Will need some fender trimming but it's easy.
pert much the whole Yellow section starting at the bodyline.
You'l have to bend a little lip flat adn you Can put the
inner fender panel back in and look stock(almost).
« Last Edit: January 21, 2006, 07:39:20 PM by HotRod »
Offline Kp7
Re: 97 sidekick 4x4
« Reply #4 on: January 22, 2006, 07:15:51 AM »
Would a coil spacer help with the clearance.
Offline da_tub
  • 307
Re: 97 sidekick 4x4
« Reply #5 on: January 22, 2006, 08:17:39 PM »
yup   ( ;))
91 four door ,and some stuff
