Removing the Pan
Removing the Pan
jor
15
Removing the Pan
April 28, 2009, 03:21:20 PM »
87 Tintop, stock engine
I
'm trying to get my pan off which looks to be attached with RTV. Anyone have a tip on how to break that damn RTV seal. I'm trying to slip a putty knife in there but so far, no go. Thanks.
jor
norcalwreckchaser
128
Re: Removing the Pan
April 28, 2009, 03:26:06 PM »
I have used a rubber hammer, lightly tapping around the pan. Or from the top of the engine use a wide flat screwdriver and tap the lip of the pan downward. Good luck
Norcal
86' Samurai, 5" spua lift, rear missing links, 4.57 gears, 4 to 1 Transfer Case, Lockrights F/R, ARB Front bumper, Doug Thorley Header, Rock Rails, GM alt. swap and other Misc. goodies.
Sold 7/10
jor
15
April 29, 2009, 07:49:41 AM »
Thanks. I'll try the mallet and pry today.
jor
sammypro.com
153
Reply #3 on:
April 29, 2009, 10:39:03 AM »
thin razor blade, round and round combined w/ the pry method!!!!!! you will eventually here a large sucking sound....that means success!!!!!
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some freakin' muscle.
http://www.facebook.com/#!/sammypro
norcalwreckchaser
128
Reply #4 on:
April 29, 2009, 02:41:26 PM »
When you get the pan off, use a wire brush to clean off that old goo! Also works well on the block itself.
Norcal
Sold 7/10
one mile
174
Reply #5 on:
April 29, 2009, 09:34:13 PM »
jor, You need to remember that a slow constant pressure will help it release. I agree with all the above suggestions but it is one of those things you have to "Feel" your way through. It sounds like you understand not to force it or rush it. I myself am going to have to do just what you are doing in the near future. GOOD LUCK!
"WORK SMART NOT HARD"
jor
15
Reply #6 on:
April 30, 2009, 07:28:12 AM »
Thanks to all. I got it off. Tried with a putty knife for awhile along with a rubber mallet. I finally touched the front lip with a long 2X4 and gave it a restrained whack and off it came!.
jor
