99 vitara differential slipping
chard
I Love ZUKIWORLD!
February 08, 2006, 12:48:31 PM »
i have yet to find out what the real problem is with the front diff. I sounds like it skips a tooth with a big clunk noise. Does any one know?
the_maplebar
466
Re: 99 vitara differential slipping
February 08, 2006, 02:00:12 PM »
Welcome to Zukiworld.
I haven't had any problems like this with mine. It would probably help if you explained your problem a little better. Does it happen when you are engaging 4wd, all the time, only at certain speeds etc.
http://www.zukiworld.com/forum/index.php?topic=35.msg111575#msg111575
[/url]
Quaddawg
1622
Flex and Ground Clearance is HIGHLY overrated!!
February 08, 2006, 02:24:24 PM »
Sounds like you have a broken ring or pinion... or spider gear in the front diff..
I would make sure it isn't your CV's though....
