A-arm drop brackets?
  • 37 Replies
  • 7047 Views
Offline MKOLSEN22
  • 217
  • Come on 32's
« on: April 28, 2007, 07:20:22 AM »
So who out there has built some brackets to drop the a-arms?  I've seen Whitfield's set up, but has any one else done it?  Pictures?  Issues?  How did you deal with the steering linkage?  Any pictures of the steering set up you ended up with?
I'm thinking about designing a set of drop brackets that will be laser cut and bent that will move the a-arms down 2 - 3" and it will incorporate the Hagen widening trick on the rear a-arm drop bracket.  This should push the axles forward 1" IIRC to help make even more room for a larger tire w/o rubbing.
If / when I do this project I will add the 2" screw on strut extensions to help compensate for the drop of the struts with the a-arms.  I will also be fabricating some differential drop brackets.
Any thoughts or help from you guys would be appreciated.
Offline tipover
  • 422
Re: A-arm drop brackets?
« Reply #1 on: April 28, 2007, 09:56:39 AM »
I have the procomp drop brackets sitting on the floor.  I wonder if i reproduce them will anyone buy them?  I bet you can add with other lifts to go a little higher...
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #2 on: April 28, 2007, 10:28:01 AM »
Can you take some pictures of the brackets from all angle and post them?  I've heard of the pro-comp lift but never seen any of their components.
Thanks!!
Offline tipover
  • 422
« Reply #3 on: April 28, 2007, 02:40:31 PM »
i'll try to get to it.
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #4 on: April 28, 2007, 06:03:02 PM »
I would be interested...
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #5 on: April 28, 2007, 08:03:34 PM »
That would be awesome. ;D ;D ;D
So does anyone have any insight into the steering linkage dilema when dropping the a-arms?
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #6 on: April 28, 2007, 08:10:48 PM »
Maybe using a drop pitman arm and somehow lowering the idler arm would solve the steering issues?
1993 4-door Sidekick
4.24:1 t-case
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #7 on: April 28, 2007, 11:21:44 PM »
Does anyone know if a Sammi pitman arm would fit the Sidekick Gearbox?  I've seen dropped pitmans for the Sammi, but not for the sidekick.
Enjoy!!
Offline Fity
  • 49
« Reply #8 on: April 30, 2007, 04:32:26 PM »
The Track/kick power steer has a larger diameter spline, so the Sami drop pitman arm won't fit unless resplined (which I have seen done).  I'm sure that I have seen a drop pitman arm for Track/Kick power steer box when used in a Sami.  I just can't remember where  :)
Offline crikeymike
  • 713
« Reply #9 on: April 30, 2007, 04:39:37 PM »
I had a drop pitman arm on my first sidekick in Australia (although i didn't know at the time that i didn't need it).  I don't remember what brand it was though.
4.24:1 t-case
Offline tipover
  • 422
« Reply #10 on: May 03, 2007, 10:10:20 AM »
Here ya go.  pro comp did not address the steering issue as stock angles are not square to begin with.  with this kit it is 2 1/2" off one way while stock is 1 1/2" the other way. I have these brackets to reproduce something close to it, but I may sell them.   These brackets also allow over a 1/2" adjustment for width.
Offline MKOLSEN22
  • 217
  • Come on 32's
« Reply #11 on: May 03, 2007, 09:54:22 PM »
Thanks for the pictures.  I'll be checking them out with great interest.  You might have mentioned it already but how much of a drop does this bracket set provide?
Offline tipover
  • 422
« Reply #12 on: May 03, 2007, 10:08:59 PM »
2 3/4"
Offline crikeymike
  • 713
« Reply #13 on: May 04, 2007, 11:16:17 AM »
Those brackets don't look too bad.
What was the story with the ProComp lift anyways?  Did they just not sell enough, or was it not very functional?
4.24:1 t-case
Offline tipover
  • 422
« Reply #14 on: May 04, 2007, 11:40:27 AM »
I have a Pertersens mag from 1995 when the kit first came out and the price was almost 700.00.  no demand back then.  I came acrossed this one so I could reproduce them but maybe at an even 3".  the hardest part is making the alignment cams... do you think that there is a demand?
