where do 31's rub?
  • 1411 Views
Offline Chief
  • 678
  • Whaddya lookin at??
where do 31's rub?
« on: August 15, 2004, 11:28:13 AM »
Looking at getting new tires in the not so distent future, so I need to know where they would rub and if I could cut em to fit. I have 30's right now and rub the frame at full lock. I would also be getting a set of 2" spacers, and running the stock alloy rims. I also have about 1-1.5" of lift from spacers.
So where would I rub at??
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
Re: where do 31's rub?
« Reply #1 on: August 15, 2004, 02:54:32 PM »
If anywhere at the back of the fenders would be my guess.
Offline Utah_Tracker
  • 179
« Reply #2 on: August 16, 2004, 12:47:26 AM »
I'm running 31's with 3 inches of lift, in the front it rubbed at the bumper cover until it was removed. Now only rubs on the frame while turning.
 The Back would grabb my rear bumper cover as well and at full flex would grab the top of the wheel wells.
91 soft top Tracker, 3' Calmini Sup, locker around, Auto, & no Power Steering
GO BIG or GO HOME
Offline lokomonkey
  • 41
  • I love YaBB 1G - SP1!
« Reply #3 on: August 16, 2004, 08:14:19 AM »
what if you put 1.1/8" coil spacers plus 2" wheel spacers, would that solve the rubbing??
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #4 on: August 17, 2004, 01:37:15 AM »
biuld a $30 body lift and don't worry about rub. i have a CUOTSM FABBED :) body lift cost $35 or so but mine is    4 1/2" so i had to do some extra work. i also run rocky road spring spacers 1 1/8" and can fit 33's with a little rub at full compression. oh swamper ltb's. yes i did trim some sheet metal off the fornt feders not much.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Chief
  • 678
« Reply #5 on: August 17, 2004, 10:18:16 AM »
OK, so some 2" spacers (for the wheels), then 1 1/8 spacers I have and a 2" body lift and some fender massaging will clear 31's. Good to know!!
