e g r code after header/2"exh
  • 9 Replies
  • 2043 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« on: February 04, 2004, 03:30:25 AM »
Hey guys,
I recently put calmini header on my 94 tracker I also added a 2" complete exh. sys. w/ flowmaster. Now when it's cold it seems to hesitate and surge when under load. Also the ses light came on the other day and I scaned it and pulled a code 51 EGR PROB. Has anybody ran into this prob after exh work :-/
            Thanks,
                 Kevin
P S I dont have a cat.
  • 6602
  • 69
Re: e g r code after header/2"exh
« Reply #1 on: February 04, 2004, 06:35:53 AM »
Hey guys,
            Thanks,
                 Kevin
The later model egr systems have a temperature probe on the valve. It may be possible that your EGR ductwork/piping is plugged up enough that there isn't enough flow recirculating to heat up the sensor. This could be exaserbated by adding a free flowing exhaust.
Don't know about your surging problem....
This is just a SWAG. Anyone else got an idea? :)
Offline 1bigtracker
  • 3409
« Reply #2 on: February 04, 2004, 06:44:37 AM »
if you don't have a cat the i wouldn't worry about the EGR.  i am going to block mine off this spring.
Stu
  • 6602
  • 69
« Reply #3 on: February 04, 2004, 09:23:27 AM »
Stu
You'll get a check engine light though if you have the temp sensor egr valve. Maybe a resistor can be placed in there to fool the computator?
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #4 on: February 04, 2004, 03:32:08 PM »
I looked at my EGR today and I do have the temp sensor I'll try and run all the diag. on it. Ithink that its a back press. sys. and now I don't have much :-/ It runs good though' if you let it warm up. :)
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #5 on: February 05, 2004, 01:36:53 AM »
Have you tryed clearing the codes and seeing if they return?  Some times they set when something new is done.  So you can try resetting the computer and letting it learn the new system.
Just a though, plus it's cheep.
96 Tracker
32 MTR's Warn 8000i
Offline Natebert
  • 1098
« Reply #6 on: February 05, 2004, 01:38:10 AM »
We too, are currently experiencing code 44 and code 51 and was suspecting the EGR sensor on the front of the motor, but have not yet determined the exact cause of the problem, keep us posted on your progress.
~Nate
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #7 on: February 05, 2004, 03:55:50 AM »
I think I'll try the clearing of the codes first, I will let you know
            see ya,
              Kevin
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #8 on: February 09, 2004, 10:56:21 AM »
Well I ran about 100mi. out in the desert so far no checkeng light ;)
Offline DSHornet
  • 250
  • Logs and Sidekicks don't mix well at 60 MPH.
« Reply #9 on: February 09, 2004, 02:17:15 PM »
When I put the Calmini header and exhaust on my late '94 'Kick I didn't run into this problem, but I had already cleaned my EGR valve passages. I even had a 0.007-inch pneumatic restrictor in the EGR valve vacuum line to delay its opening a second or two.
It's true, if you're running less back pressure with an EGR valve that is mostly plugged, the temperature sensor won't get hot enough and the ECU will interpret this as an EGR problem.
Don, y'all
Paw-paw Don, y'all
.Late '94 Sidekick 1.6 ragtop, slightly modified.
Favorite saying: "One need never apologize for exercising the Golden Rule."
