What a difference!!!!!
  • 33 Replies
  • 8720 Views
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: What a difference!!!!!
« Reply #30 on: May 23, 2004, 04:27:17 AM »
I had to relocate the lower and upper shock mounts.
Lower the axil untill the spring is just loose and mount the bottom of the shock.
I then took a sawz-all and cut off the upper bracket.  Attached it to the upper shock and welded it back to the frame.  The new location stuck up above the frame about 1 1/2 inches.  So I added a 45 degree bracket to the top of the shock bracket to the top of the frame.
96 Tracker
32 MTR's Warn 8000i
Offline Kreg
  • 795
  • Yo Ho, Yo Ho, a four wheelers life for me.
    • Island 4x4
« Reply #31 on: May 24, 2004, 01:59:03 PM »
So what shock will give me maximum travel without relocating the upper shock mount?
I suppose it all depends on where I relocate the lower mount to... So I guess my question is, what kind of shock should I get which will ride softer, and have enough length to offer me maximum travel without relocating the upper shock mount?
« Reply #32 on: May 24, 2004, 11:13:31 PM »
I did the rotation and kept my Calmini shocks, and only relocated the lower shock mount. It gives me prety good rear wheel travel
Though I do plan on doing adjustable rs9000 when I blow out a Calmini Shock.
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #33 on: May 25, 2004, 02:25:49 AM »
I aM pretty sure the rear shocks from 2wd 99 f150 will do that for you.
Mike
