My samurai's capabliity?
  • 12 Replies
  • 2105 Views
Offline SamuraiGuy7
  • 80
  • My Samurai
« on: September 16, 2006, 09:08:47 AM »
hey guys i think i want to go to moab in april. its right on my birthday and that would be a blast. only thing is ive never been to moab or really wheeled my samurai in anything too dificult. Im working on it right now but by april it will have: 5.38's. a rear spool. 33-34x12.50's. i wont be running a winch. i doubt if ill have beadlocks. COULD but not likley unless you guys strongly advise it, a front locker. its on a spring over with wrangler conversion. have k and n and full 2 inch on the stock 1.3. rebuilt t case, ford shock towers,over the top steering, soon to have power steeruing. Is there anything i should really put my $$ towards to prepare for runs like poison spider and some of these runs at moab? i really need some imput here.
Appreciate it,
Taylor
87 Samurai
     4x4
Offline locjaw
  • 2045
  • 22
Re: My samurai's capabliity?
« Reply #1 on: September 16, 2006, 10:00:30 AM »
poison spider is a relatively easy trail
you gonna be just fine with the setup you have right now
80% of the trails in moab are fairly easy ;)
and you have a winch, so you will have no problems.
been there 5 times in different levels of vehicles and always had lots of fun
last year we took dad's 96 tracker 2"+2" lift, 30" bfg AT's, locked in the rear and t-case gears. we had a blast going thru obsticals with a tire 3' in the air. we only got stuck once, and that was because I had to try to be a tough guy and take the hard line ::)
you gonna love it
and i'll see you there :D
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
« Reply #2 on: September 16, 2006, 10:47:39 AM »
You should be fine, friends of mine went there with all stock SPOA samurais, and did most everything but the extremely hard stuff.
« Reply #3 on: September 16, 2006, 06:33:32 PM »
As long as you stay off the hard trails you should be fine.  I would recomend a winch ahead ofa  front locker, even if it is Harbor Freight special.  It will help you get over more things then a front locker.
Offline kirknd4spd
  • 333
« Reply #4 on: September 16, 2006, 11:45:47 PM »
and you have a winch, so you will have no problems....
he never said he had a winch, he said he would NOT be running a winch.
but a winch would be a really good idea
89 Sidekick - 2 door soft top, 1.6, auto, 4x4, 3" suspension lift, 31x10.50's on 15x8 Mickey Thompsons, long tube header
Offline locjaw
  • 2045
  • 22
« Reply #5 on: September 17, 2006, 08:34:53 AM »
oops, my bad
jason
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #6 on: September 17, 2006, 10:51:52 AM »
I think another good thing to think about is a thurough inspection of your brakes, make sure everything is in great condition, brake fluid lines, etc. Loosing your brakes on any trail sucks.
Offline SamuraiGuy7
  • 80
  • My Samurai
« Reply #7 on: September 17, 2006, 07:36:32 PM »
hey good to know, i could do a winch, but then i have a bumper, bigger alternator, the winch, a second bat....hmm if its going to be better than a front locker than mybe ill try and have a winch by then, or mybe even both :) ... appreciate the feedback
87 Samurai
     4x4
« Reply #8 on: September 17, 2006, 10:09:36 PM »
I still run my stock 410 alt.  But I did upgrade to a dual 6v battery setup to soak up the juice.  After winching a long hill it usually take about 30 minutes to charge. :P
Offline urbanwheeler
  • 696
« Reply #9 on: September 18, 2006, 01:09:29 AM »
Is the SJ410 a 6 volt system, or are you using two 6 volt batteries in the place of one 12 volt battery?
« Reply #10 on: September 18, 2006, 10:49:00 AM »
The 410 is a 12V system, I'm running two heavy duty 6V batteries in series to run as a 12V.  My brother and a buddy put it together for me while I was at work because they decided my previous battery wasn't up to snuff.  The 6V supposedly have more amps then the 12v batteries.  He is the mechanic in the family, I just shadetree stuff so I took his word for it.  But I have never run out of juice while winching.  :D
Offline SamuraiGuy7
  • 80
  • My Samurai
« Reply #11 on: September 19, 2006, 07:34:33 PM »
hmm, well if all i needed was a second bat, i might jsut go ahead with a winch.
87 Samurai
     4x4
Offline holeypockets
  • 68
  • i think DENTS are pretty
« Reply #12 on: September 21, 2006, 06:16:21 PM »
my cousin did pritchett canyon without any problems, the hardest one on the list.   he just had lockers, 31s, 4:1 and spoa at the time.  hes a really good driver though, i couldn't do it.  so i think you'll be fine with anything there as long as your comfortable with the vehicle.
i just like dents, i don't know why.
