O2 sensor
O2 sensor
bus_driver
479
the voices tell me different things
O2 sensor
July 26, 2006, 08:57:53 PM »
I have to ask if I am on the right path....my kick is burning the spark plug tips white my fuel mileage has dropped(worsened) and now my truck idles a little higher...1000rpm and when I start up I have a but load of gas out the exhaust
I am thinking my O2 sensor is not working properly is there anything else
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
derekj
784
i'm the canadian guy eh?
Re: O2 sensor
July 26, 2006, 10:12:03 PM »
out of range coolant temp sensor will cause it to run really rich.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
32" TSL's and some other stuff I did And now with a Lockrite!
www.cardomain.com/memberpage/783382
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: O2 sensor
July 27, 2006, 04:51:28 AM »
White plug is a lean mixture, that and the high idle would seem to indicate an air leak in the intake.
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
bus_driver
479
Re: O2 sensor
Reply #3 on:
July 27, 2006, 10:06:50 AM »
the part that confuses me is how is it pure burning gas out the back and then lean at the plugs.... does that not contradict each other or is that just becuz i have no CAT.....
i first thought of an air leak i think i will take like wd40 and pray around the throttle body and check for any change.....
thanks guys
92 2dr soft top
235/75/15
2 inch lift
custom mud
Rhinoman
4502
36
Re: O2 sensor
Reply #4 on:
July 27, 2006, 03:15:54 PM »
I once started mine up without the master cylinder attached. It idled high, popped a bit and had white smoke coming out the exhaust. It definatley had an air leak, lol.
wildgoody
8134
67
Re: O2 sensor
Reply #5 on:
July 27, 2006, 06:55:01 PM »
Pure gas coming out the back? like dripping?
or could this be water, sure it's not coolant?
that creates white smoke too, and would do
funny things to the plugs as well as drip out
the tail pipe.
bus_driver
479
Re: O2 sensor
Reply #6 on:
July 31, 2006, 12:50:37 AM »
what i mean is raw burning gas not drippping like burn your eyes type of burning and then the spark plugs are burnt white and there is a a new one if I drive gentle the truck idles high if I drive like normal .....beating the piss out of it all the time it idles perfectly fine.... oh well got the o2 sensor now so will replace that and check it all again....
92 2dr soft top
235/75/15
2 inch lift
custom mud
