amp tester for new alt?
  • 7 Replies
  • 1972 Views
Offline 90Stomper
  • 427
« on: March 13, 2005, 03:06:44 PM »
no one i know could think how to do this in the car...?  so i spent the big buck ($7 :D) and bought a amp gauge.  but try as i might i cant get my head around how to wire it in my 90 with 3 wire set up.  the dumb guage only has two wires, a + and -!  how hard can it be.... to much for me i guess.  any advice from anyone that has done this?  i suck at wireing. >:(
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline mrfuelish
  • 2862
Re: amp tester for new alt?
« Reply #1 on: March 13, 2005, 03:24:31 PM »
You cut the big wire in half and insert the gage, prob the plus on the alt side.
Offline 90Stomper
  • 427
« Reply #2 on: March 14, 2005, 04:50:15 AM »
see i did hear somthing like that, but it seemed wrong because i would be cutting an 8g wire to insert a 14g wire in it. ???
Offline mrfuelish
  • 2862
« Reply #3 on: March 14, 2005, 06:22:44 AM »
If the wires are small on the gauge you may be missing half of it.  check to see if the gauge is a volt meter. try it on a small battery first like a d cell batt.
Offline 90Stomper
  • 427
« Reply #4 on: March 14, 2005, 01:46:44 PM »
after rechecking i guess there are no wires, just bolts to hook wires too.  i was looking at the small wires for the light in the guage :-[  but, if i splice into the wire going from the alt to the bat. then i need to run 8g wire from there throught the firewall to the gauge and back.  is that correct?  still seems odd but if that is right i'll do it :o
Offline zukizzy
  • 123
  • Give it a bump, see what happens!
« Reply #5 on: March 15, 2005, 12:15:03 AM »
I hate ampmeters you have to run all the power from your alt though it i for it to work right which means 6 to 8 feet of heavy wire for things to rub on and make neat sparks and smoke. plus a voltmeter gives you more useful real time info. I have one in the shop to test alts with but I run volt meters in all the rigs I have.
my .02
Wayne
Clearly a road
Offline mrfuelish
  • 2862
« Reply #6 on: March 15, 2005, 03:57:22 AM »
correct, you can get one with a shunt if you do not want to use yours.
Offline 90Stomper
  • 427
« Reply #7 on: March 15, 2005, 04:11:48 AM »
thanks for the good info all!  i will have to think about it for a bit.... :-/
