another stupid mistake
  • 1772 Views
Offline crgm101
  • 80
« on: July 22, 2008, 05:17:18 PM »
help please i accidentely returned my crank with the woodruff key in it and now have no woodruff key with the reman. it is a 1987 suzuki samurai 1.3 8 valve if anyone knows the size it would be great i am sure hawkeyes has them but it is a very small order and is the last part i need to put the motor back togethor
Offline HOGCAT
  • 20
Re: another stupid mistake
« Reply #1 on: July 22, 2008, 05:39:54 PM »
  If ya have a good machine shop by ya get one a tad bigger and file it down.  They are soft, easy to do.   And be sure to torque it down good.  It depends on the tightness of the nut to keep the crank and pulley in sync.  the key is just to index it right.
  Also Harbor Freight has a whole plastic box of all different sizes for 10 bucks.  Probably one of them would work.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: July 22, 2008, 05:48:21 PM »
It is quite possible that you can get one at your local auto parts store!
O'Reilly Auto Parts have a selection of common-sized Woodruff keys at prices from $.29 to $2.69.  They may be in inventory or available in as little as three hours from a nearby warehouse.
I am sure that other auto parts stores can do the same thing.
Just measure the slot's width and depth, dump all the change in that mayonaisse jar sitting on your dresser into your pockets and rush out in a buying frenzy to the nearest auto parts store!  Buy a bunch of similar-sized woodruff keys.  Return the ones that do not fit for a refund.
EDIT: as crgm191 mentioned, MAKE SURE THAT YOU PROPERLY TIGHTEN THE CRANK BOLT  More G13 and G16 engines get screwed up by improper torquing of the crank bolt!
If you don't have the torque specification, you can find it by downloading the appropriate section of the 1988 Suzuki Samurai Factory Service Manual (FSM).  Do a search for fsm at ack's FAQ (the link is in my signature, below) to download a copy.
I hope that this helps!
« Last Edit: July 22, 2008, 05:54:45 PM by ack »
Ack
Offline RHodge
  • 523
« Reply #3 on: July 22, 2008, 07:52:32 PM »
Did you Know that O'reillys just bought CSK, so thay are now the 3rd biggest chain of part stores
