where is ECM & what's it look like?
  • 8 Replies
  • 1861 Views
Offline joezuki
  • 133
  • zukiworld rocks!
« on: June 19, 2005, 10:45:14 PM »
I have a '92 4 door automatic daily driver.  I got audiovox's aftermarket cruise control last week & was going to install it over the weekend.  It needs to be connected to the vehicle speed sensor wiring, & they say it should be a yollow wire coming out of the ECM.
I assumed it was behind the dash, but after looking at all the wires, switches, modules, etc...  I figure I'll give you guys a shout.  It looks kind of easy, but I don't want to hook up to the wrong wires. Any help will be appreciated.............Thanks!
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: where is ECM & what's it look like?
« Reply #1 on: June 19, 2005, 11:06:23 PM »
under the dashboard on the driver' side next to the door
Ack
Offline joezuki
  • 133
  • zukiworld rocks!
« Reply #2 on: June 19, 2005, 11:19:11 PM »
Do you know how big it is & what it looks like?  Color?
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #3 on: June 20, 2005, 12:30:36 AM »
It's grey, about an Inch high and about 4 Inches wide and 5 long I believe. Had mine out recently to have it repaired, it's tightened with just 2 bolts. It's behind the fuse box somewhat.  ;D Good luck on your search  ;)
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline joezuki
  • 133
  • zukiworld rocks!
« Reply #4 on: June 20, 2005, 01:20:23 AM »
I'll take a look at break time & see if I can find it.
Offline 1bigtracker
  • 3409
« Reply #5 on: June 20, 2005, 04:36:53 AM »
to remove the box take the drives side lower speaker out and remove the 2 10mm( ???) bolts and just be easy taking it all down.  there are about 5 relays and a fuse block that come with it.
stu
Offline joezuki
  • 133
  • zukiworld rocks!
« Reply #6 on: June 20, 2005, 05:38:31 AM »
YUP...there it is! :o
maybe i'll have cruise control for tomorrow ;D
THANKS ALL ! ::)
gotta love these smileys...eh? ;)
Offline joezuki
  • 133
  • zukiworld rocks!
« Reply #7 on: June 20, 2005, 05:42:27 AM »
Oh, & for anyone else who is interested, you can pick up a cruise control unit here:
http://store.yahoo.com/brandsplace/0002-ccs100.html?source=inksitematch
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #8 on: June 20, 2005, 11:00:01 AM »
Nice to hear you found it  ;D and yes we do like smileys  ;)  ;D
I allready have CC in some kind of way, if I put a stone on the gas it won't go over the speed limit on highways over here  ;D
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
