bad water pump or thermostaton Sammy? (No, My Stupidity)
  • 1744 Views
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« on: December 22, 2007, 06:46:11 AM »
I did my timing belt and water pump as well had the thermostat out. Got it started after figuring out the timing belt was off a tooth. Now, it overheats. The fan never comes turns. From the front of the engine, the fan impeller shaft turns easily by hand but is not turning at all while the engine is over-heating. >:D
I'm going to put a brand-new thermostat in it or run without to see if the impeller and or the fan clutch engauges once it gets hot.
Am I on the right path or is there something else I should be looking at? ???
If I can turn the water pump by hand when the engine is hot, doesn't that mean that no coolant is flowing by it to turn it?? ???
Update:
I changed the thermostat and it still overheats. Lower radiator hose feels pretty cool about half way back and the heater control valve is cool. No coolant coming to the heater. No heat.
When it cools down, I guess I'll try flushing just the radiator with a hose in the top and the bottom hose disconnected?? It wasn't doing this before I did the waterpump but maybe when I emptied the radiator, something sunk to the bottom and clogged it ???
Any help always appreciated.
-Adam
« Last Edit: December 22, 2007, 12:54:17 PM by daddyizzle »
If all criminals were behind bars, there would be no one left to patrol the streets.
86 Samurai Tin-Top stock with a Harley 44 sidedraft carb
Offline mrfuelish
  • 2862
Re: bad water pump or thermostaton Sammy?
« Reply #1 on: December 22, 2007, 11:46:45 AM »
Do you have the fan belt on? how can you turn the pully by hand if it is on?
Offline daddyizzle
  • 728
Re: bad water pump or thermostaton Sammy? ( No My Stupidity!!)
« Reply #2 on: December 22, 2007, 12:53:30 PM »
 :-[ :-[I guess I need to clean up my garage. I had it off to the side on top of my tool box. + my memory isn't what it use to be. I try to keep everything together when I tear stuff down and because it wasn't near by, I overlooked it and putting it together, it seemed o.k. I guess I better not quit my day job. :-[ :-[  Maybe I should blame it on the other guy (like my brother in law) :laugh: :laugh: Thanks alot. You've made a difference! ;D ;D
Happy Holidays!!
-Adam
« Last Edit: December 22, 2007, 12:57:29 PM by daddyizzle »
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: bad water pump or thermostaton Sammy? (No, My Stupidity)
« Reply #3 on: December 23, 2007, 07:23:15 AM »
Zing!
XL-7 front coils
1.5" rear coil spacers
