Help me identify 562's
  • 12 Replies
  • 1808 Views
Offline Quaddawg
  • 1622
    • My Ebay Store
« on: February 02, 2006, 06:29:20 PM »
My wrecking yard has 8 trackers/kicks... which had the 5.62's?
Offline wezzlegod
  • 227
  • under construction crowler
Re: Help me identify 562's
« Reply #1 on: February 02, 2006, 08:13:15 PM »
88 and 89 1300 carbarated
black 89 sidekick toyota 22re L52 5speed trans w/ duel t cases. toyota axles w/coil springs 4 link double triangle 3 link front, 5.29 r&p, lockers ,35x12.5 tires, rock rails ,custom plate steal bumpers, killer xm sounds ext ext ext
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #2 on: February 02, 2006, 08:21:55 PM »
Ah, thanks... of course, I am pretty sure I am outta luck.. but I am still making the call!!
Offline locjaw
  • 2045
  • 22
« Reply #3 on: February 03, 2006, 07:32:31 AM »
dreamer ;D
jason
Offline 1bigtracker
  • 3409
« Reply #4 on: February 03, 2006, 09:35:52 AM »
wana pick up a set for me too? :D :P
Stu
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #5 on: February 03, 2006, 11:06:22 AM »
yep, it was a long shot, the oldest tracker they have is a 92.. but they do have at least 5 trackers there, one guy says they have 8.. .the other says 6.. but I have seen 5, and scrounged parts off 3 of them..
Hey, it was worth a shot.. you never know....    :'(
Offline Mythose
  • 361
« Reply #6 on: February 03, 2006, 01:45:41 PM »
what is the easest way to tell which gearing is in your rig if you are uncertain?
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #7 on: February 03, 2006, 01:52:02 PM »
Put a vertical chalk mark on your tire where it contacts the ground and put a mark on your driveshaft. Roll the vehicle along the ground until the tire has done one complete revolution and at the same time count how many revolutions the driveshaft does eg. almost 5 & 1/2 would be a 5.38 but a bit past 5 & 1/2 would be 5.62. It's not exact but knowing the different ratios available for these diffs you should be able to tell which one is in yours.
Offline BigPig
  • 276
« Reply #8 on: February 03, 2006, 02:17:42 PM »
The 5.62's look exactly like the ones in the Tracker I'm selling whole! :)
;D Buy my Tracker w/Gears and Locker! ;D
« Last Edit: February 03, 2006, 02:27:35 PM by Big Pig »
'89 Sidekick w/ 4.5" of lift.
Offline Mythose
  • 361
« Reply #9 on: February 03, 2006, 04:08:25 PM »
kewl i will do that to see.
Offline locjaw
  • 2045
  • 22
« Reply #10 on: February 03, 2006, 08:07:14 PM »
i believe that the 5.62 gears only were in 88' and 89' 1300cc carberated rigs
fwiw
jason
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #11 on: February 04, 2006, 08:04:13 AM »
Yeah!  DONE!  NOW,  if I an get MRfuelish to call or pm me back..... it will be a done deal..
NOW, I have a set of 5.12's, possibly with a locker or mini-spool for the rear... What are they worth?
I was thinking $225 for the 3rd's  and and extra $150 if there is a locker installed, or an extra $90 if there is a mini spool installed (haven't decided which to keep the spool or the lokrite)
95XL7
« Reply #12 on: February 04, 2006, 09:38:16 AM »
Check www.car-part.com put in your area for the search and see what you come up with.
