AUTO HUB QUESTION ???
  • 23 Replies
  • 5455 Views
Offline track_this
  • 332
Re: AUTO HUB QUESTION ???
« Reply #15 on: November 04, 2003, 06:20:06 PM »
super winch vs. warn.  what is the difference and has anybody run the hub fuse from the warn hub? im curios if that might limit breakage to just a fuse that is only 40.00 dollars??
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
  • 6587
« Reply #16 on: November 05, 2003, 12:48:07 AM »
Seriously, run the stock Aisin hubs (Lockouts as Mikey calls them.) I've run Superwinch, Warn, and Warn Premium... all of them had problems with bolts loosening, even with locktite. I was unfortunate enough to actually chuck one of the Warn Premium hubs while going down the road. Where is it? I don't know...
Offline Z3bra
  • 273
« Reply #17 on: November 05, 2003, 02:31:06 AM »
Safety Wire will stop any problems I guarantee.
That said I've had my Warn premiums for about a year and a half just using the locktite and no problems with any of the bolts even thinking about loosening up on me.
Was gonna drill em for safety wire but the socket head bolts eat drill bits in my safety wire jig.  (Cobalt bits even).  Usually breakage rather than going dull, that 12.9 hardened stuff is tough.
  • 6587
« Reply #18 on: November 05, 2003, 02:45:27 AM »
So will using the stock hubs! :)
Offline Z3bra
  • 273
« Reply #19 on: November 05, 2003, 08:36:39 AM »
Not in my case, my auto hubs were pretty much hosed due to corrosion, plus having 2 low is occasionally handy anyway.  Getting out to lock em being the only obvious drawback to the whole conversion.
If you have auto's and they're not working right (i.e. not releaseing as intended).  It does affect your milage plus it can  cause additional wear in the front end, CV joints etc.  Not much admittedly but 100 bucks for warn premiums vs who knows how much for replacement auto hubs made the choice pretty easy for me.  I did try to find some sammy/kick hubs in a junkyard first (auto and manual) but didn't have any luck anyway.
Besides, safety wire is inherently kinda sexy.
« Last Edit: November 05, 2003, 08:37:39 AM by Z3bra »
  • 6587
« Reply #20 on: November 05, 2003, 09:03:15 AM »
I'll give ya the sexy part. :) There are stock MANUAL hubs for the Sidekick too and in my experience, most junkyards basically give them away for $10-$25 bucks...
« Last Edit: November 05, 2003, 09:04:10 AM by ebewley »
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #21 on: November 05, 2003, 11:07:08 AM »
THANKS WILDGOODY AND MR NSX  ;D   MAYBE NOW I CAN POST SOME PICS. :o ... ITS TOUGH BEING P.C. & MECHANICALLY CHALLENGED :-[  BUT I'LL KEEP ASKING AND LEARNING  ::)
« Reply #22 on: November 05, 2003, 01:27:14 PM »
I have a set of auto hubs, $10 plus UPS
thats what I got in em, the Manual
hubs are holding up fine, I got hte autos
just for spares, cheap enough so y not?
NY kicker, no worries, I'm PC and Mechanically Inclined
so I share what I know, and ask all the questions I can.
;D
« Reply #23 on: November 05, 2003, 01:31:43 PM »
And about the hub fuse, I heard they don't work
well on the Suzukis, seems the fuse is about as
robust as the zuke axles, so it's a toss up as to
which one goes first.
