Axle shaft/brake swap??
  • 7 Replies
  • 2461 Views
95XL7
« on: May 27, 2004, 09:05:01 AM »
Are GV axles shafts the same length as the 98 and below shafts? I got a line on a complete rear brakes and axles/bearings from a G.V. and want to know for sure if this will work. ???
  • 6589
Re: Axle shaft/brake swap??
« Reply #1 on: May 27, 2004, 10:01:22 AM »
No. For bigger brakes get the 4-door sidekick rear brake assemblies The backing plate with all the guts and the drums. They are quite a bit larger than 2 door and bolt in their place using your stock axle housing and axles. Front discs and calipers from a 4-door are bigger as well and they too bolt in place.
HTH -Eric
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #2 on: May 27, 2004, 11:03:16 AM »
Stuart,
     Still got my eye open for some four door brakes for you.  I've been stuck working 42 of the last 45 days, been hard to get out and rummage thru the U-pull it like I want to.
95XL7
« Reply #3 on: May 27, 2004, 12:42:48 PM »
The guy that has them said they would work if i use the bearings with the axles? ???
He has the axles, bearings,backing plates,drums hardware,etc.
Damn it, i want axles with the studs on em' not the drums.
Offline 90Stomper
  • 427
« Reply #4 on: May 27, 2004, 01:55:10 PM »
this is good to know!  do the years have to be the same, or should i ask, what years will work on my 90 tracker?
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #5 on: May 27, 2004, 02:39:57 PM »
94 and older will bolt on a 90 tracker. Also XL7- If you want to retain the studs on the axle you should also go with the94 and older 4 door parts.
Mike
95XL7
« Reply #6 on: May 29, 2004, 01:57:49 AM »
Well i checked and the 99 2 door and GV rearends are the same width,same part#.
Now is the vitara 2 door rearend wider than the 98 and below??
Are the axle tubes bigger or just inside bearing diameter and the outside diameter the same?
Axles might be longer due to the wider drums? ???
  • 6589
« Reply #7 on: June 01, 2004, 02:31:26 AM »
If you want this, get 96-98 Sidekick axles. Go walkin' through the junk yard and you can get these. I was using the 5 -bolt flange Sidekick axles with appropriate drum. BUT in my experience these axles are actually worse than the 4-bolt flange axles. The metal seems even more brittle, if you can believe that, I'd stick with the 4-bolt axle flange and the 'drum brake adapter' system.... :)
