LIFT
  • 7 Replies
  • 3115 Views
Offline Mythose
  • 361
LIFT
« on: June 24, 2005, 07:43:23 AM »
I cant find the link to the instructions for the strut flip, or for the 3 inch body lift, was gona have my machien budy cut me out the parts. now that she is running good
maby go and get the diffrent springs and flip the strut and have a tall kick
Offline Cwkick
  • 888
Re: LIFT
« Reply #1 on: June 24, 2005, 07:51:44 AM »
Offline Cwkick
  • 888
Re: LIFT
« Reply #2 on: June 24, 2005, 07:52:47 AM »
Offline Mythose
  • 361
Re: LIFT
« Reply #3 on: June 24, 2005, 08:13:24 AM »
Thank you but i was looking for the instructions on making the body lift
Offline Cwkick
  • 888
Re: LIFT
« Reply #4 on: June 24, 2005, 08:57:56 AM »
Offline Mythose
  • 361
Re: LIFT
« Reply #5 on: June 24, 2005, 10:42:18 AM »
no that is the goods
thanyou
Offline lokomonkey
  • 41
  • I love YaBB 1G - SP1!
please help, what did I do wrong??
« Reply #6 on: June 30, 2005, 10:27:58 AM »
 ???hey guys I just tried to put spring spacers and flip the struts in the front, but couldn't  get to take the strout out (forget about flipping them) and the spring didnt get release or drop enough to access it, so I just put everuthing back together and run for help (that's why I'm here....)
Offline SnoFalls
  • 1358
Re: LIFT
« Reply #7 on: June 30, 2005, 11:10:31 AM »
Here's my steps ... (others have their own way ...)
1) remove the anti-sway bar (if you haven't thrown it away yet)
2) jack the a-arm up (you'll need access to the 3 nuts below the ball joint so get jack positioned carefully!)
3) undo the strut mount (and strut shaft nut if your going to flip the mount).
4) remove the nuts holding the ball joint and swing it out from under the arm.
5) lower the arm slowly, and spring should fall out.
Reinstall by ...
1) Get your spacer and spring properly positioned up top, and set in the recess at the bottom best you can.
2) Start jacking the arm back up. This is tricky cuz the jack will wanna slip (and you need it be clear to get the ball joint back under). I've used 2 jacks before. One to get the spring compressed into the arm, then a bottle jack to hold it there while I remove the other and get the ball joint mounted back under the arm.
3) Get the ball joint under the arm and bolts snugged.
4) reattach strut mount (and strut shaft if undone earlier)
5) torque everything properly!
Be careful! That spring has considerable forces applied to it.
