positive camber after calmini 3" lift
  • 12 Replies
  • 2913 Views
Offline satan inside
  • 68
  • bodylifts are for rednecks
« on: September 04, 2006, 03:53:06 AM »
seems i have alot of positive camber after having the 3" sus lift installed.  kinda weird, i thought only the rocky road type lifts affected the camber.  wheres the cheapest place to get camber bolts?
Re: positive camber after calmini 3" lift
« Reply #1 on: September 04, 2006, 04:43:07 AM »
You bought into Calminis advertising then? Camber is nearly always a problem with IFS irrespective of lift manufacturer. The nose weight of the vehicle affects ride height and that causes camber changes. You may find that it will correct itself once the front end has settled down, otherwise a search here will find several different vendors named.
Offline Mike71
  • 1449
« Reply #2 on: September 04, 2006, 05:00:18 AM »
what year is your truck? my grandpa put a lift (well i put it on lol) on his 02 4door and we had to finally get calmini to admit that their front spirngs were made to have the extra weight of a bumper and/or winch on the front
so as it say stock the springs were not carrying enough weight  ::)
623hp kb cobra sold! 100hp kick new DD :P
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
« Reply #3 on: September 04, 2006, 03:21:36 PM »
Should have taken a pics after my lift install, way out.
Just adjust it yourself by eye then take it to a wheel alignment shop.
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
  • 68
« Reply #4 on: September 04, 2006, 06:14:27 PM »
well its a 95 tracker.   i bought the lift kit used from explosivo and it seems to be broken in already.  the front is not much higher than the back. why does calmini say it wont affevt camber when is obvously does.
so where is the cheapest place to get camber bolts?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: September 04, 2006, 06:20:59 PM »
Most autoparts stores sell them.  I know NAPA and Advanced Auto do.  Make sure you're getting the Ingals made stuff.
Offline Jeff@TireBalls
  • 559
« Reply #6 on: September 04, 2006, 06:25:40 PM »
Slotting the holes works well too.
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #7 on: September 04, 2006, 08:59:06 PM »
....or just jump it a couple times till your strut towers bow in a little.
j/k - slotting the holes is good and cheap, and I think stronger than cam bolts.
Offline ZeusZuki
  • 411
« Reply #8 on: September 04, 2006, 09:10:42 PM »
Uncivilized - niiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiice  ;D
Thats the spirit  ;)
ZeusZuki  8)
sapien
« Reply #9 on: September 05, 2006, 06:26:28 PM »
I got mine on EBay, $20-25 for the pair, search for part# 81250
the bolts make it easy to very precisely dial in the camber, but if you're out more than a couple degrees then you still might need to oval out the strut holes
Offline Mike71
  • 1449
« Reply #10 on: September 06, 2006, 02:49:31 AM »
on the newer kits calmini says to cut 1/4th of a coil off the bottom till the camber sits right  ::)
  • 559
« Reply #11 on: September 06, 2006, 04:44:08 AM »
LMAO.....you have got to be kidding????
  • 68
« Reply #12 on: September 06, 2006, 01:29:35 PM »
well i went wheeling, caught a little air here and there and one side has settled and is almost correct. the black rubber thingy above the spring is not all the way in on the other side. maybe it will settle over time.
