Look what I've got! (stronger CV's)
  • 24 Replies
  • 3186 Views
Re: Look what I've got! (stronger CV's)
« Reply #15 on: September 16, 2005, 08:13:32 AM »
Explaine how you hammered to get the CV
apart, I know there is a snap clip in there,  but
I can't get them apart, been trying to figure
how I could use a press, but a press pushes,
not pulls, which is what is needed here
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #16 on: September 16, 2005, 09:52:33 AM »
Here's a pic of the actual Joints compared:
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #17 on: September 16, 2005, 10:02:47 AM »
No snap clip in mine, I looked at the Chilton's and it said a snap clip indeed but I just started tapping nicely on it and it came apart pretty easy  ???. So there was none  ;) Maybe the manual is wrong but I couldn't find it (no groove for it either).
Press should be used to insert the shaft into them, because it has more even pressure less chance of damaging it.
But I've poked around in it with a screwdriver after they came apart and there IS a groove in the CV itself, so there should be but it isn't  ???
And now I'm looking closer to the drawing in Chilton's and the outer CV's (the ones at the wheel) don't have a C-clip on them. The other side however does have m in. But I think that would be able to come apart too. I'll try to get the pic on the comp big enoug to see...
Sorry for the long post but I was thinking and looking and typing at the same time  ;)
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
« Reply #18 on: September 16, 2005, 01:52:03 PM »
I can't see that CV joint very clearly because of the gease. Is it bigger? if so roughly how much bigger?
« Reply #19 on: September 16, 2005, 06:59:01 PM »
Well you know the stub side of a front
diff, it has a little clip to keep the axle
stub shaft in the side gear, I was thinking
the outer CVs had the same sort of clip
to keep the axle shaft in the CV, that and
there has to be a way to assemble the thing
mudfkr
« Reply #20 on: September 16, 2005, 07:26:37 PM »
100% correct - move to the top of the class please  ;D
I hold the shaft in the vise the hit the back of the cv with a soft face hammer, some times the clip is reusable afterward and others it not so be careful.
Occasionaly the clip pops into the cv and hids in the grease so make sure you check youv'e taken it out before reasembling it.
Of couse if youv'e blown the CV to bits it much easier to change  :-[
« Reply #21 on: September 16, 2005, 07:32:38 PM »
Thanks Mud, I thought as much.
I've never blown an outer CV, just
the cage on 1 inner  ;)  so much for
blowing CVs with a 3" suspension lift
 ;D
mudfkr
« Reply #22 on: September 16, 2005, 07:52:11 PM »
I must be a whore then cause I've "blowen them All"  ;D
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #23 on: September 16, 2005, 08:23:16 PM »
I've broke a bucket full of inners when I had the standard tranny in there but never an outer. Now that I have the auto tranny I haven't broke one. Auto tranny=Poor mans gearing ;D
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
« Reply #24 on: September 17, 2005, 12:53:31 AM »
I think the auto trans applies smooth power,
not the snapping as with a clutch, I just shattered
the cage, I could of fixed that on the trail with a new
cage (I carry a spare now)
