truck won't start...
  • 1227 Views
Offline AsuperCoolName
« on: July 02, 2010, 04:26:50 PM »
its a 93 sidekick JLX, It turns over but doesn't start, the EGR is making a clicking sound. any ideas?
Offline beagle..t
  • 1239
  • 16
Re: truck won't start...
« Reply #1 on: July 02, 2010, 10:29:09 PM »
sounds like ECU computer
« Reply #2 on: July 03, 2010, 12:37:31 AM »
but would that keep it from starting?
« Reply #3 on: July 03, 2010, 09:49:57 AM »
EGR is clicking?  Are you sure?  The EGR on yours is vacuum operated, there are no electronics that go to it....unless you have a cali spec one...then all that goes to the EGR is a temp sensor...which shouldn't ever click.
If there is something under the left side of the dash that is clicking, then it is probably either the main or fuel pump relay.  The ECMs are known to go bad in these....that would be my guess.....if it was operating fine before and you haven't did anything to make it not start.
« Reply #4 on: July 03, 2010, 01:42:19 PM »
give it a shot of starting fluid, if it starts it could be the fuel pump
or the ECU, which activates the injector
