Service Engine Light - P0440
Durango65
22
November 13, 2006, 08:31:14 PM »
Need some help fellow zuki lovers. My 2000 2.5 litre Grand Vitara has given me the Service engine soon light 4 times now with the same P0440 code coming each time I scan with the OBD II scanner. Replaced the gas cap as per my Suzuki dealers advice and now I am stumped. Anyone else out there have this issue? 440 is a Evaporative Emmisions System Malfunction?
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: Service Engine Light - P0440
November 14, 2006, 04:49:42 AM »
Check the pipes around the charcoal canister. Also the electrical connections to the Vacuum Solenoid Valve (VSV).
OBD1 - Full diagnostics on a PC/Laptop:
http://www.rhinopower.org
FNG
197
91 TRACKER 6" LIFT ON 34S, SKID PLATES AND CAGE
November 14, 2006, 06:00:27 AM »
fuel tank vent malfunction, possilbe faults are- faulty evap canister purge valve,blocked fresh air line,leaking line between evap canister and intake,purge valve incorectly installed or leaking. this fault means that it is not seeing a change in the o2sensing when the purge valve is activated.find the purge valve and use a 12v source to activate it and listen for it to click and the check the fresh air line for a clog possibly mud from off roading. hope that helps
good luck with your diagnosis
Last Edit: November 14, 2006, 06:07:44 AM by FNG
Durango65
22
Reply #3 on:
November 14, 2006, 09:01:34 PM »
Thanks guys this is all awesome. Just a couple of novice questions, where do I find these lines and evap canister? And where is the fresh air line, and the Purge valve?
FNG
197
Reply #4 on:
November 15, 2006, 06:07:50 AM »
you may need to invest in a factory repair manuel.i do not have the diagrams you will need
to identify the purge valve or the path of the fresh air line
