Better rim size.
  • 8 Replies
  • 1828 Views
BIG DOG
Better rim size.
« on: February 03, 2008, 09:34:25 PM »
What is the better rim size for a 31x10.5 tire?8" or 10"? The reason I ask is I have a chance to get a set of 15x10" rims with a 2" back spacing . I have planned all along to get the ford or jeep spoked rims with a 8" width. But these have come along and I wonder what they might be like?Any input will be appreciated!
Thanks!
They will be going on a 95 16V 5spd tracker with a 2" body 2" spring spacer.Thanks!
« Last Edit: February 03, 2008, 09:36:24 PM by BIG DOG »
Re: Better rim size.
« Reply #1 on: February 04, 2008, 01:00:29 AM »
Some people run the 10" wide rims, but I am more of a fan of the 8" rim unless you are running 14" wide tires.  The problem with the wider rims is when you air down it makes it easier for the tire to pop off the bead.
BIG DOG
« Reply #2 on: February 04, 2008, 03:28:53 AM »
What about the way the rim width effects the thread any advantage or disadvatage between 8" or 10"?
BIG DOG
« Reply #3 on: February 04, 2008, 12:29:00 PM »
A lot of you say you have steel wagon wheels in the ride forum ......what are they?
MaD.72
« Reply #4 on: February 04, 2008, 12:37:57 PM »
Run the 8"!! The 10" rim is probably larger than the widght off the tread on the tire
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #5 on: February 04, 2008, 01:11:34 PM »
10" wide is a little to wide for a Kick. They would stick out past the fenders a bit as well. An 8" wheel is the perfect width for a 10.5" tire.
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
spyder0069
« Reply #6 on: February 04, 2008, 10:11:59 PM »
I run the 15x8 with that tire size on my 92 kick and they work great.
big_kountry21
« Reply #7 on: February 04, 2008, 10:20:02 PM »
i have 15x8 with 3 in and 5 out. no problems now i'm runnin 235/75/s
BIG DOG
« Reply #8 on: February 05, 2008, 03:37:16 AM »
Great my plan was always to run 8" but these 10" came along and I was just wondering if they would work.
Thanks!
