New 2" BDS kit for the 4dr trackkick
  • 13 Replies
  • 2897 Views
Offline the_maplebar
  • 466
« on: April 14, 2006, 04:07:42 PM »
I noticed that BDS has updated their installation instructions to include an application for the 4dr trackkicks.  The catalog hasn't been updated yet, but if you want a 2" lift without coild spacers this might be a good option
http://www.bds-suspension.com/php/Inst_Srch.php?veh=7
Offline Shredder
  • 389
  • She thinks my Tracker's sexy
    • Me & My Rig
Re: New 2" BDS kit for the 4dr trackkick
« Reply #1 on: April 14, 2006, 05:48:46 PM »
Boondox has some of those BDS springs in their "Garage Sale". Here is the link.
http://www.boondoxmotorsports.com/garagesale.html
'96 Astro Van 2wd, +10 Overland, 32s, Tow Rig
'96 Tracker LWB 4x4, +4.5 Calmini/Boondox, +3 Boondox BL, 31x10.50 (wife rolled)
'93 Sidekick LWB 2x4, 235s, +3 Boondox Suspension kit, 4wd swap 2b
'91 Tracker SWB, Toy axles, YJ Springs, Boondox Swap Kit, 31x10.50
  • 466
« Reply #2 on: April 15, 2006, 09:11:31 AM »
SWEET!!! I hadn't seen the garage sale section before.  So is Boondox going to offer any kind of strut spacer/extension or just the OME struts.  The BDS Strut extensions seem really slick, and don't screw with the strut brace like a spacer that lowers the mounting surface.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: April 15, 2006, 01:23:46 PM »
I just ordered a set  of those extensions at my local BDS dealer for my Digger lift.  Now all I need is a set of towncar shocks and a successful triple-bypass surgery!  :o  Wish me luck!
Ack
Offline Shredder
  • 389
    • Me & My Rig
« Reply #4 on: April 15, 2006, 04:40:50 PM »
I would think so. I will ask about it on Monday.
Offline jeffry
  • 87
« Reply #5 on: April 15, 2006, 08:01:00 PM »
So would those strut extensions work well with an existing OME springs/struts lift? I could certainly use the two extra inches of drop it gives, but would it mees too much with my CVs since I already have OME struts and springs up front?
Thanks, jeff
How much did they cost from BDS? I don't see them separately.
Also, anybody dare to compare the BDS springs with the OME springs?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: April 15, 2006, 09:50:01 PM »
You should be able to get them for $35-45 a set from your local BDS supplier.  the_maplebar and I both paid about that much.
Ask for part number FSE3.  If they say it doesn't exist have them call BDS and ask.  Also, FSE3 is a SET, you don't need to order two FSE3's...you'll get two sets in that case.
Offline bus_driver
  • 479
« Reply #7 on: April 15, 2006, 11:19:45 PM »
any one know of a dealer in toronto.....canada that is you know.
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
« Reply #8 on: April 16, 2006, 08:06:10 AM »
It would kill your CVs. The OME struts are already 1 1/2" longer. From the measurements that I've taken 2" is the max without lowering the front axle.
Offline jeffry
  • 87
« Reply #9 on: April 16, 2006, 01:48:02 PM »
thanks, don't want to kill CVs ...
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #10 on: April 16, 2006, 05:50:35 PM »
No, but I bet BDS does.
http://www.bds-suspension.com/php/distributor.php
Offline DWiddowmaker
  • 59
« Reply #11 on: April 17, 2006, 07:26:05 AM »
It says on Boondox that the spring would work on SWB, but would be firm... How firm. Like invest in a back surgery firm? I can drive a Super Pro car down the streat in a Aluminum seat and be a little sore, would this be that bad? Also they will work on a '92 right?
Offline Shredder
  • 389
    • Me & My Rig
« Reply #12 on: April 17, 2006, 08:03:59 AM »
I think they said that because they had a customer who used them on the two door even though the spring rate is designed for a four door. He had a heavy bumper and winch in front and also HD rear bumper with heavy spare tire so it helped compensate for the added spring rate. I think they might not be bad on a generation II shorty but I would think it would ride like a brick on a 2 door Geo or 'Kick. If you have a '92 SWB I don't think I would use them. I think you would also get too much lift. I asked about them for my shorty and they said not a good idea.
I just came from Boondox. They have 20 sets of those strut extenders in stock. $45 a set.
« Last Edit: April 20, 2006, 01:30:05 PM by Shredder »
  • 466
« Reply #13 on: April 19, 2006, 07:47:32 AM »
I called http://www.boondoxmotorsports.com to get their BDS shocks.  Steve is a very nice guy, I also found out that they have a bunch of the BDS Strut Extensions on order that they will being stocking along with some other cool stuff in R&D that they aren't announcing yet.
