Rock-Steady 4.5" Combo kit or the Calmini 3" suspension - Which one???
  • 14 Replies
  • 4404 Views
Offline longarch
  • 61
Rock-Steady 4.5" Combo kit or the Calmini 3" suspension with maybe a 2" body lift, which do you prefer? Please speak from expierence.
'94 Tracker W/Hard Top
1.5" Front Coil Spacers - 2" Rear Coil Spacers - 2" Strut Spacers
30x9.50x15 Cooper Discoverer STT's
Calmini Front & Rear Tube Bumpers
Bored 30 Over & Head Shaved
Swapped 4:42 gears for 5:12's
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
   The rock steady lift rides better,but it is only 1.5 inches of suspension lift.The calmini is 3 full inches of suspension lift and a very complete kit.
  If I was gonna wheel it alot I would get the calmini kit
KING ZOO!!
Offline ROSS
  • 1412
the nice on calminis is later you can get the shackle reverse for a complete 5" of lift
Offline longarch
  • 61
Dummy me forgot to state that I was installing the lift on a Tracker. Sorry.
Offline RJkick
  • 634
I have the Calmini 3 suspension lift on a '92 4dr sidekick.
In a perfect world the calmini kit would have the OME struts and springs, shocks are a toss up on the kits so you could get some better gas shocks, and the rest of the parts are best with Calmini.
I haven't heard to much lately but you can ask Calmini if they have a spring rate closer to OMEs' which come with the RockSteady lift
Offline longarch
  • 61
Thanks for the info rjkick.
PS - you can order the OME struts separately. Not sure if they're better than the Calmini versions.
Offline cj
  • 1276
  • I drive a really big ATV
Much better!
Offline RJkick
  • 634
And at the moment the longest travel strut for the Zuk.  Calmini is coming out with a long travel strut but no idea when and they have noo info on when.
OME has the better struts and springs currently which makes the hybrid suspension lift more expensive than a complete kit by any manufacturerer
Has anybody on the board tried out the Rock-Steady lift yet?
  • 6598
  • 68
Yep. Check the Gear Guide...
http://www.zukiworld.com/month_090105/feature_rockyroad_rocksteadylift.htm
Ah, my mistake.  I was thinking of the Zuki Nation lift as I didn't recognize the name.  I should have double checked.
Offline olija
  • 770
    • Check out my cardomain
Has anyone tried running 89 Hyundai Pony 4WD wagon struts up front? I read on another forum that they will bolt up if you remove the coil spring seat (Hyundai has a true MacPherson strut whereas Suzuki uses a modified setup where the spring is separate from the strut). I also read that they are 1.5 or 2" longer than stock so I'd like to see someone try this!
Offline bzzr2
  • 1011
so try it out and let us know!
09 taco reg cab short box 4x4
Offline RJkick
  • 634
What is the link to the other board write up?
