vibration at 60+
  • 2670 Views
Offline TheLastSamurai
  • 48
  • 91' TFI
vibration at 60+
« on: November 16, 2015, 03:11:20 PM »
ok, so I went wheeling in Ocatillo wells, broke my drivers side t-case mount. put a bolt with washers as a temp fix till I get new ones. I expected more vibration but at 60+ it gets worse than regular cruising. If I put my t-case in N and shift through all the gears with engine on I get nothing except 4th and 5th there is a vibration. I'm thinking U-joints on the intermediate shaft or a possible bearing. Thoughts?
Re: vibration at 60+
« Reply #1 on: November 16, 2015, 03:32:54 PM »
I would look at those first, then the u-joints in the rear driveshaft.
For the t-case mount did you add a spacer in the middle to keep the t-case sitting at the correct angles?
  • 48
  • 91' TFI
« Reply #2 on: November 16, 2015, 04:44:46 PM »
yes, I matched it up with the old mount to get the same height out of it.
« Reply #3 on: November 17, 2015, 05:54:27 PM »
Some of the 'unbreakable' t-case mounts are just some rubber bushings with a bolt through them.  I ran those for years without issues, never broke a mount.  I did break a t-case...
Were you able to check for any slop in the u-joints?
  • 48
  • 91' TFI
« Reply #4 on: November 17, 2015, 06:34:09 PM »
yes, no play in the u-joints, but when i lift the rear end off the ground and put it in drive the t-case makes some bad noises. I think it might be done...
Offline kreator
  • 634
  • 15
« Reply #5 on: November 18, 2015, 08:41:30 AM »
Sounds like you have a wheel bearing out, thats was my vibration
« Reply #6 on: November 18, 2015, 03:07:25 PM »
Small issues are always a pain.  Might be something a simple as loosing a tire weight as well.
