35's
  • 11 Replies
  • 2306 Views
Offline Real_Red_Sammi
  • 43
  • Make it hurt!
35's
« on: July 12, 2004, 03:00:05 PM »
     So I got the stock gears in my sammi, and I have 35's, and it moves fine. Gears are for burnin' too much money. I also have a 1.6 to help me out, so I figure I got that going for me. Anybody else using stock gears, and big tires on there sammi!
"I do what I want"
LMS wasted my time
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
Re: 35's
« Reply #1 on: July 12, 2004, 03:09:37 PM »
  Damn, you are stressing those axles and the clutch. I heard of people running those tires, but were open diffed and only did trails. No deep mud or rock crawling, unless you did a grs2 or more. Would like to see a pic of the sammy though. How much lift and what type of wheeling you do?
Offline 1bigtracker
  • 3409
Re: 35's
« Reply #2 on: July 12, 2004, 05:41:54 PM »
well i have 34's on my tracker and everyone thinks i'm crazy(and cheap).  but hey if it works...
stu
Re: 35's
« Reply #3 on: July 13, 2004, 12:26:17 AM »
stu
What engine do you have? a 16V has around 18% more power than an 8V, so I shouldn't think its much different to running an 8V on 31s
Offline supazuk
  • git 'er done!
Re: 35's
« Reply #4 on: July 13, 2004, 12:39:58 AM »
I'd start looking for some toys
it'll be a lot cheaper then a tow home
shut up and wheel it.. sick of hearing oh my (fill in blank) stock can climb mountians yet the only off roading its seen is the curb their g/f ran over!
Offline real_red_wagon
  • 226
  • Make It Hert!!!
Re: 35's
« Reply #5 on: July 13, 2004, 04:11:09 AM »
I'VE SEEN HIM WHEEL IN MUD COVERING THOSE 35'S ABSOLUTEY MAJESTIC IF YOU ASK ME. REAL RED SAMMI'S SITTING ON A HOMEMADE SPOA WITH ABOUT 1" TALLER PERCHES AND I BELIEVE ABOUT 11/2" TALLER SHACKLES LOTSA FENDER TRIMMING AND EVEN A LITTLE SLEDGE ACTION, ;D  BUT THATS THE LMS (LAKEVIEW MOTORSPORTS) WAY "CHEAP AS FREE" "MAKE IT HERT!!! :D" MY TRACKER IS FULL OF HOMEMADE TRICKS AND I MAKE IT HERT ALMOST DAILY!! OH YEAH MINES THE DAILY DRIVER TOO! WE WOULD LOVE TO POST PICS CAN SOMEONE LET US KNOW HOW?
   THE 35'S ARE DUNLOP MUD ROVERS WAY LIGHTER AND WAY CHEAPER THAN SWAMPERS OR MOST ANYTHING ELSE FOR THAT MATTER ;D  ITS THE OFFICIAL TIRE OF LMS DAMN GOOD TIRE IF YOU ASK ME :)
At Lakeview Motorsports, were wasting your time already!
Offline 1bigtracker
  • 3409
Re: 35's
« Reply #6 on: July 13, 2004, 06:32:02 AM »
8V :-/  don't get a chance to drive it on the street much.  i've only put about 200 miles on it this year. :-/
stu
Offline LawDog
  • 531
  • Lakeview Motor Sports' Makin it Hert! Tell u whut!
    • Emerling Chevrolet
Re: 35's
« Reply #7 on: July 13, 2004, 08:04:04 AM »
Mud Rovers, Mud Rovers, why are your 33/12.5's on international backorder :-[  31/10.5's are too small 8)
"I'm the Law 'round here" said the Duckshirt.
Get a Zuk, Get it dirty, Git-R-Done!!
At Lakeview Motor Sports we specialize in rediculousness, hackdome, and wasting your time.
  • 43
  • Make it hurt!
Re: 35's
« Reply #8 on: July 13, 2004, 04:49:00 PM »
Pics are coming soon, got to the digital camera! but i'm guessing overall about 8in. of suspension lift.
"I do what I want"
LMS wasted my time
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: 35's
« Reply #9 on: July 14, 2004, 03:46:03 PM »
I rock crawl with mine at Paragon. I'm running 35x12.50 ProComp Xterrains with 5.125 gears locked front and rear. The t-case is 6:1. When I locked the front I also ringed the joints and haven't had a problem. The only problem I've had was the rear axles. I twisted splines and snapped both sides at once. (third gear wheelies don't help the matter) I did bend my rear axle but since my last outing I welded a gusset I made. The toyota rear shaft and traction bar I made really help as far as reliability.
 For lift I have 4" BDS springs, 5" leaf over, and 5" folding shackles with shackle reverse kit. And no, It's not tipsy!
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline flexmonger
  • 209
Re: 35's
« Reply #10 on: July 14, 2004, 04:42:32 PM »
, Black sammy, With that much lift and tires it is a matter of time. I wheel with 33's and 1-1/2" lifted wrangler springs with 6.5's and 5.38's. I do lots of wheel stands also because of the gearing and break stock rear sammy axles. But since upgrading to chromoly rears they seemed to have survived. I also upgraded the front birfs with rings and the front shafts with hardened ctm shafts. I can still blow the inner cage of the stock birf's with 2 hard wheely landings.
  Believe me dude your setup rocks hard but will break. On the other hand if we got ourselves CV Unlimited's sammy front shafts we would be set. Lifetime warranty and everything is new, bigger and chromoly and cheap at  580.00 a pair.
Offline 87BlackSami
  • 191
Re: 35's
« Reply #11 on: July 14, 2004, 04:48:58 PM »
FlexMonger:  I do my wheelies in 2wd Low so the front axles aren't a concern in that case. I've been looking for the birfield eliminator for sami axles but can only fing them for Yota. Where did you see them? Got a link? Thanks in advance.
