Broken moter mounts
  • 12 Replies
  • 2769 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Broken moter mounts
« on: August 20, 2008, 10:59:43 AM »
I keep breaking moror mounts on my kick. 8v eng 94 year has anybody else had this prob. If I wheel hard they only last 1 trip.
   Kevin
Offline ROSS
  • 1412
Re: Broken moter mounts
« Reply #1 on: August 20, 2008, 01:02:55 PM »
I've seen you drive :P :P :P
I run the heavy duty ones from TT
Offline 86badboy
  • 15
  • believe it!
« Reply #2 on: August 20, 2008, 05:48:49 PM »
teh full circle mounts are supposed to be awesome.  they also use spring bushings so they are cheap to build.
BUILT NOT BOUGHT
86 sami, spoa, RUF w/ML's, 5.14 t-case, rear lockright, 33x12.5 mud T's, rear disk brakes, custom bumpers, custom lighting....list goes on.....
Blake
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #3 on: August 21, 2008, 07:46:10 AM »
Who makes the full circle mounts? Will they work on a Kick?
   Kevin
Offline ROSS
  • 1412
« Reply #4 on: August 21, 2008, 08:39:20 AM »
petroworks does for the sammi conv.  .  call and see about the kick
http://www.petroworks.com/drivetrain-accessories.php
Offline rascott
  • 669
  • 15
« Reply #5 on: August 21, 2008, 10:58:34 AM »
i understand some people are using 318 dodge pickup mounts.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #6 on: August 22, 2008, 01:50:26 PM »
My problem right now is that the oil pan is too close to the steering drag link. Something is not right.
    Kevin
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #7 on: August 25, 2008, 07:49:14 AM »
Has anybody used the HD motormounts?
    Kevin
   Ps the dodge 318 mounts are only 1.5" wide and the stock mounts are 2.5"
Offline ROSS
  • 1412
« Reply #8 on: August 25, 2008, 07:57:21 AM »
i've been running them for several years now. haven't broke one yet.  knock on wood
Offline safarikick
  • 270
  • nor-cal rhinos
    • http://www.cardomain.com/id/safarikick
« Reply #9 on: August 25, 2008, 07:08:09 PM »
can you use the dodge motor mounts i a kick with a 16v
3+3 calmini 5.12 a lock in the back and front with steel front diff. 4.24 in tc
Offline 86badboy
  • 15
  • believe it!
« Reply #10 on: August 25, 2008, 07:53:55 PM »
anything is possible with a lil cut and weld... :P
BUILT NOT BOUGHT
Blake
« Reply #11 on: August 26, 2008, 05:05:14 PM »
You can also fill the stock mounts with 3m window weld, its a very strong urethane that bonds to rubber well, it tries to a rubber like consistency. works great for stiffening up motor mounts, have used it on most of my vehicles for years.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #12 on: August 26, 2008, 05:25:19 PM »
I tried to order some HD motor mounts from Low range but he called his supplier and they don't make any for 92 and later kicks. So whats the deal, is a heavy duty motor mount not available? I guess I'll just have to fab up some full circle mounts. I do have some rear control arm bushings but I think that I'll get some bad vibes if I use them.
   Kevin
