broken speedometer- tracker
  • 9 Replies
  • 7050 Views
Offline tonyman246
  • 58
« on: October 22, 2009, 10:11:30 AM »
what could be the cause of my speedometer not working? all the other gauges work but the speed o doesnt.
1991 Geo Tracker 33" super swampers + 4" lift + minor fender trimming + locker = unstoppable!
  • 6587
Re: broken speedometer- tracker
« Reply #1 on: October 22, 2009, 10:13:32 AM »
Possibly the cable has came out of the back of the gauge cluster or you have broken speedo cable.
Offline Minmatar
  • 262
  • That lake is just too clean....right zuki? >=)
« Reply #2 on: October 22, 2009, 11:35:22 AM »
Also note that the cables do need to be lubed if you hear squeeky squeeky
<)O.o(> NO!!!!! *as the sidekick rolls* My beer =(
« Reply #3 on: October 22, 2009, 03:55:19 PM »
Does your odometer work?
Offline tonyman246
  • 58
« Reply #4 on: October 23, 2009, 11:16:18 AM »
wow now that you say squeaky squeaky i did hear that when i bought it and now i dont have a speedo and yes the odom does work. i will be checking if it came unpluged some how this evening and ill be back
« Reply #5 on: October 23, 2009, 05:57:04 PM »
If the odometer works and the speedometer does not then the speedo is broken.  You need to buy a new speedo gauge and switch to it.  For some reason in the later models the pin that the speedo uses likes to break.
Offline tonyman246
  • 58
« Reply #6 on: October 24, 2009, 09:49:50 AM »
drats now i need a new speedo too along w a cable?
Offline zukimoo
  • 330
« Reply #7 on: October 24, 2009, 06:06:34 PM »
take out the guage cluster and go for a spin....look to see if the cable is turning. If it's still turning then you only need a cluster.
06 Baja Buggy
« Reply #8 on: October 25, 2009, 12:39:23 AM »
Sorry, I had that backwards.  My bad for having a few drinks first.  :D
Your speedometer cable is fine, it's the speedometer itself that is broken.  You need to pick up a new speedometer or just a new cluster.
« Reply #9 on: October 29, 2009, 05:28:57 PM »
Have another drink.  You had it right.
I try not to think when I drink, or after.
